ᐅ KALLAX surface rough after heavy use – should it be sanded again?
Created on: 31 Mar 2016 19:38
Pelle35
Pelle35
31 Mar 2016 19:38
I have a KALLAX shelf at home that I’ve been using intensively for about 3 years now – mainly for books and decoration. I’ve noticed that the surface has become noticeably rougher over time, with some areas looking scuffed or worn. The surface no longer feels as even and smooth as it did at the beginning, which is especially noticeable when running your hand over it.
My question to you: Is it advisable to sand down the KALLAX surface to make it smooth and visually more appealing again? Or are there common issues to watch out for, considering the material is a coated wood composite? Has anyone had experience with sanding or other treatments to remove the rough texture without permanently damaging the shelf or losing its protection?
Looking forward to your opinions and advice!
LuMarcel43
31 Mar 2016 20:11
Pelle35 schrieb:
Is it a good idea to simply sand down the KALLAX surface to make it smooth and more visually appealing again?
That’s an interesting question. First of all, it’s important to identify what kind of coating is on the surface. KALLAX is known for melamine resin-coated particleboard. These surfaces are very durable but are not designed to be mechanically worked on.
Sanding can damage the protective layer and significantly reduce both the stability and resistance to moisture and scratches. This means that without a subsequent sealing or coating, you would be left with an exposed bare particleboard, which will be more prone to damage.
I’m curious whether you plan to sand by hand with sandpaper or use a machine, and what grit you intend to use. Very fine sandpaper might slightly roughen the surface and smooth out minor imperfections, but achieving a completely smooth, like-new finish is unlikely.
In my opinion, sanding alone without follow-up treatment is risky and could actually make the problem worse.
bupar
1 Apr 2016 08:44
Pelle35 schrieb:
Does anyone have experience with sanding or other treatments to remove the rough texture without permanently damaging the shelf or losing its protective layer?
When it comes to surface treatment of KALLAX furniture, it is important to know that these are usually coated particle boards. They are not comparable to solid wood.
- Sanding removes the melamine resin layer that protects the material.
- After sanding, a new surface finish such as painting or oiling must be applied to prevent moisture damage.
Alternatives to “smoothing” could include:
1. Cleaning with a special melamine remover or a mild abrasive pad (to remove dirt and contaminants without excessive material removal).
2. Using furniture care products that can slightly refresh the surface.
3. Light polishing with fine sandpaper (e.g., grit 400+) only spotwise and carefully.
Very important: Professional furniture restorers rarely sand melamine surfaces but prefer repairs or complete replacements.
Conclusion: If sanding is done, it should be clear that the shelf needs to be painted or sealed afterward. Otherwise, further wear may occur more quickly.
lochen
1 Apr 2016 10:27
LuMarcel43 schrieb:
Sanding can damage the protective layer and significantly reduce both stability and resistance to moisture and scratches.
That’s true, and I completely agree with that. Based on my experience using KALLAX furniture, the surface does not tolerate heavy mechanical treatment.
If the surface has become rough, this is often caused by dirt or small scratches that have settled in. I recommend starting with a thorough cleaning using a mild, soap-free cleaner and a microfiber cloth.
bupar schrieb:
Alternatives could be cleaning with a special melamine remover or mild abrasive pad
Exactly, an abrasive pad (very fine texture) can gently help smooth out roughness without going deeply into the material.
It’s important to check after each step if it’s sufficient. When sanding, I would use no coarser than grit 320 to avoid completely damaging the surface.
In general: if you don’t have the option to reseal the surface afterward, I would advise against sanding.
Good luck!
barge
2 Apr 2016 13:02
Hey Pelle35,
I know this issue well – the KALLAX can start to look a bit rough, almost like it’s already had a few stories to tell! 🙂
I wouldn’t recommend sanding it down completely, as that can be quite tricky with an “Ikea classic” like this. My suggestion: try gently using a soft sanding sponge with fine grit, but be very careful. You could also try a furniture polish spray designed to hide small scratches.
If small spots remain visible later, you could touch them up with a furniture marker or paint in a matching color to refresh the appearance.
And yes, maybe just embrace the look as a kind of ‘patina’ sometimes – it can add character. Good luck experimenting!
Lyndon55
3 Apr 2016 09:15
Pelle35 schrieb:
Is it advisable to simply sand the KALLAX surface to make it smooth and visually more appealing again?
Here is a brief guide and assessment:
1. Material check: KALLAX is usually made of particleboard with a melamine resin surface. This surface is not designed for mechanical sanding.
2. Preparation: If you still want to try it, make sure to get fine sandpaper (grit 400 to 600).
3. Sanding: Use only very light pressure and sand along the grain direction to avoid sanding through the surface.
4. Aftercare: Since the coating will be damaged, resealing is absolutely necessary afterward – for example, with clear varnish or special furniture oil.
5. Risks: Uneven sanding can cause unsightly spots. Also, the surface will lose its protection against moisture and scratches.
My advice: If the surface is not completely worn out, it is better to sand lightly and then treat it with care products rather than sanding aggressively.
If you decide to sand, test it on an inconspicuous area before treating the entire surface.
