ᐅ Kallax stored in the basement after moving out – has a musty smell
Created on: 15 Dec 2022 09:27
Mofar
A few months ago, I stored my Kallax shelf in the basement after moving out of my apartment. Since placing it there, I’ve missed the natural scent of the wood – by now, the shelf smells quite musty and doesn’t seem very fresh anymore.
The basement is heated but also relatively humid and not ventilated very often. I placed the shelf directly on the floor, without any cover or special measures.
My question is whether the musty smell typically results from the damp basement environment, and if there are any proven methods to remove or at least improve the odor with minimal residue.
Are there also options to treat the shelf afterwards, or would it be better to remove it completely from the basement?
Any ideas or experiences would be very helpful, thanks in advance!
LUISABEL
16 Dec 2022 08:39
I will summarize the main points:
- Musty odors mainly arise from moisture accumulating in the MDF edges and the surface coating.
- The basement should ideally have a relative humidity below 60%. This can be achieved through room ventilation or technical dehumidifiers.
- Furniture placed directly on the floor absorbs increased moisture, which intensifies odor formation.
- Cleaning with a 5% vinegar solution removes microbial deposits and reduces odors.
- After cleaning, store the furniture in a dry, well-ventilated area, preferably not permanently in the basement.
Regarding "post-treatment": Impregnation of MDF is difficult since the melamine coating is non-porous. However, on the cut edges, a wood preservative stain or specialized edging paint can help reduce moisture peaks.
Recommendation: If basement storage is unavoidable, first check the humidity level with a hygrometer and improve the room conditions. Place the shelving on spacers, clean it with vinegar water, and use odor absorbers such as activated charcoal.
This systematic approach is the most promising way to reduce the musty smell.
