ᐅ Reinforcing Kallax Shelving Under the Desk – Is Installation Difficult?
Created on: 21 Mar 2024 08:37
Antonio4
Antonio4
21 Mar 2024 08:37
I am planning to install a Kallax shelving unit from Ikea under my desk to create additional storage and keep my workspace tidier. The idea is not to place the unit freely on the floor but to reinforce and securely attach it underneath the desktop so that it is stable and can bear weight.
Now I am wondering: How practical and effective is it to mount and reinforce a Kallax unit under a desk? Are the installation tasks, especially the reinforcing and fastening under the desktop, particularly tricky or time-consuming? Which methods and tools would be best suited to ensure the shelf holds securely without damaging the desk?
I have already considered using screws, brackets, and even glue, but I am unsure if there are better solutions or specific tips to keep in mind.
I look forward to your experiences and advice!
neoren
21 Mar 2024 09:02
Mounting a Kallax unit under the desk is possible, but you should definitely use sturdy brackets and avoid placing the screws too close to the edge of the shelf, as the material can tear out easily. It also helps to prepare in advance by pre-drilling the holes before screwing.
Surela
21 Mar 2024 11:24
Interesting approach, Antonio4! Installing a Kallax unit under the desk does require care, mainly because the panels of the Kallax are not designed to permanently support transverse loads.
In detail:
- First, you should check how the shelf itself will be loaded and what weights you plan to store there.
- For mounting, I recommend sturdy steel metal brackets, preferably with a thickness of at least 2-3 mm (0.08-0.12 inches).
- Be sure to pre-drill holes both in the Kallax panels and in the desktop. The panel thickness of the Kallax is not very high, so use screws with a short thread to avoid tearing out.
- If possible, reinforce the connection additionally with wood glue – this provides more stability, even though it does not replace a load-bearing screw connection.
- The connection at the side panels of the Kallax is particularly critical; here, it can help to place small strips or wooden battens between the shelf and the desktop to create a larger bearing surface.
- Use high-quality metal dowels or connectors for the desktop when screwing in the shelf. Make sure to keep a minimum edge distance of 20 mm (0.8 inches) to prevent tear-out.
I’m also curious: What kind of desktop do you have? Solid wood, chipboard, plywood? This significantly affects the mounting method. Do you have a workshop space or tools like a drill, cordless screwdriver, or clamps?
theo63
21 Mar 2024 13:11
Surela schrieb:
Installing a Kallax unit under the desk indeed requires care, especially because the Kallax panels are not designed to support transverse loads permanently.
That is correct. I would even go further and generally question whether using the Kallax as a load-bearing element beneath a tabletop makes sense. The design is intended for upright use on the floor, not for suspended loads.
In addition, the point about "tricky installation" should not be underestimated: screw connections in the Kallax can quickly fatigue and loosen, especially with repeated stress. Without additional reinforcement, the shelf can become unstable.
An alternative idea: perhaps a substructure made of wooden slats with screws would be more advisable to realize a hanging shelf with the Kallax module, so that the shelf essentially rests on a stable framework attached to the desk.
Do you have any design constraints, or do you need to remain flexible? What exactly are the most important requirements: load, appearance, ease of access when storing?
noge58
22 Mar 2024 07:49
Hello Antonio4! Mounting the Kallax shelf under the desk is a brilliant idea! 🙂 I did the same myself and can only recommend using metal brackets at critical points and pre-drilling the screws carefully; otherwise, as neoren already mentioned, the material might tear out!
At first, I was also skeptical about the installation, but with a cordless drill and some patience, it went well. It also helped me to secure everything with clamps so nothing would shift while screwing.
Don’t be discouraged by any difficulties—the result is definitely worth it, and you’ll gain a lot of space!!! Good luck, and please share how it works out for you 🙂
I’m happy to help if you need anything else!
