ᐅ Kallax no longer fits properly after painting – what can I do?
Created on: 10 Dec 2017 18:43
Kelaka
Kelaka
10 Dec 2017 18:43
I recently painted my Kallax shelf white, but now I’m having fitting issues when assembling it. Specifically, after painting, the individual shelf parts no longer fit flush together, small gaps have appeared, and especially the shelves either stick or don’t sit straight. This wasn’t the case with the original, unpainted parts. I suspect the paint has slightly changed the dimensions or the surface has swollen.
My question is: What can be done if a Kallax shelf no longer fits properly after painting? Are there techniques to adjust or modify the parts again without damaging the fresh paint? I want to use the shelf so that it is stable and looks neat, without compromising functionality.
I’d really appreciate any advice on sanding methods, refinishing, or alternative assembly options. Thanks in advance!
PIN66
11 Dec 2017 07:56
Kelaka schrieb:
What can be done if a Kallax shelf no longer fits precisely after painting?
Basically, the issue with painted furniture of this type is often caused by swelling of the engineered wood panels (MDF or particleboard) when too much moisture is introduced with the paint. With the Kallax, which uses melamine-coated panels and edge banding, the exact fit is usually designed to be precise down to the millimeter.
First, I recommend lightly sanding the problematic edges before the paint is fully dry, but carefully. Use fine-grit sandpaper (around 180 to 220 grit) and only sand the areas where the parts no longer fit. Light sanding often helps to compensate for minor dimensional changes without damaging the paint over a large area.
It can also help to slightly roughen the joints before painting or skip painting the surfaces at those points to avoid increasing the critical dimensions.
An alternative, if you really want to avoid damaging the painted areas, would be to use thin felt pads or clamp strips at certain contact points to compensate for small dimensional differences. These can be applied on the inside or less visible surfaces.
In summary: careful local sanding, using small shim pads if needed, and when re-painting, be cautious not to cover important fitting areas with extra paint.
How did you paint it and how many coats did you apply? Depending on that, the situation can be assessed better.
Natan
11 Dec 2017 09:22
PIN66 schrieb:
The problem with painted furniture [...] is often due to the swelling of the wood-based panels
I only partly agree that this is the main cause. Kallax usually has a very fine melamine coating on particleboard, which is quite moisture resistant. I rather suspect that the painting itself slightly thickens the surface through layers of paint, which interferes with the tolerances in the assembly area.
The crucial question for me is: Was the shelf completely disassembled and each part painted individually before painting, or was the painting done on the assembled shelf? In the latter case, poor fit is often to be expected because the edges rub against each other due to the new paint.
Kelaka schrieb:
Are there techniques to readjust or modify the parts without damaging the fresh paint?
In my opinion, you need to slightly reduce the paint thickness at the contact surfaces if the unit is to fit precisely. For this, it makes sense to carefully treat the edges after painting with a fine sanding sponge. In any case, you will need good sandpaper with a grit of 240 or higher to avoid roughening the paint over a large area.
Alternatively, you might consider masking the contact surfaces lightly before painting (e.g., painter’s tape), so they remain uncoated after painting – then the dimensions will match again.
Contrary to common belief, it is not the wet paint that causes the material to swell, but mainly the amount of paint applied and whether fillers or primers were used.
How many paint layers did you apply, and what type? (Acrylic, acrylic lacquer, spray?) These details can help to assess the problem more accurately.
parbau
12 Dec 2017 12:05
Natan schrieb:
In my opinion, you need to slightly reduce the paint thickness at the contact surfaces[...] carefully work on it with a fine sanding sponge.
I can only agree with that; combined with a bit of patience and humor, it works great! 🙂
If your Kallax doesn’t fit perfectly anymore, lightly sanding the edges can work wonders without ruining the entire surface. I recommend using sandpaper with a grit of 320 or even 400, very fine, just to remove the thicker paint build-up on the edges. If you sand only in spots, it’s less noticeable visually.
And when you reassemble the parts, don’t worry: small gaps are rarely visible on Kallax shelves anyway because the back panel and shelves hold everything together.
One more tip: if a slight color difference is visible after sanding, you can cover it with a matching marker or very careful touch-up painting. It’s less hassle than you might think.
So no panic, it can be done easily even without professional tools. Good luck! ;-)
