ᐅ New Kallax Color – Is Wrapping or Painting the Better Option?
Created on: 12 Jul 2024 14:23
PEBIUSHello everyone,
I have been considering updating the color of my IKEA Kallax shelving unit for some time now, as I no longer like the standard colors. The fundamental question for me is: Is it better to have a Kallax unit professionally wrapped (with vinyl) or to paint it myself?
I am especially interested in durability, appearance, and the effort involved in each option.
Wrapping seems quite straightforward and reversible, but is the result truly as long-lasting and glossy as paint? Painting appears to offer a higher-quality finish visually, but I am concerned about the potential effort, drying times, and the risk of uneven surfaces.
Does anyone have practical experience with both methods? What are the specific advantages and disadvantages for the Kallax shelving unit, which is made of coated wood-based material?
Best regards!
Best regards!
Hello PEBIUS,
your question about “Kallax new color – is wrapping or painting better?” addresses an important point, as both methods have specific advantages and disadvantages that often vary greatly depending on the goal and level of craftsmanship.
On one hand, wrapping is actually simpler: Kallax is usually made of melamine resin-coated particle board, which has a fairly smooth surface – making it well suited for self-adhesive films. The big advantage is that you can start relatively quickly and without complicated preparation. However, the key challenge lies in material compatibility and the quality of the film application. A high-quality PVC or vinyl film can look good, is easy to clean, and is more scratch-resistant than some paints. It is important, though, to thoroughly clean the surface and prepare the shelf properly—especially if there are small irregularities. The film should be applied without bubbles, which can be challenging depending on your experience. Another plus is reversibility: if you no longer like the color, you can usually remove the film without damaging the wood.
On the other hand, painting tends to have the edge in terms of appearance. If you want a particularly high-quality result, you should choose the right type of paint—such as acrylic paint or water-based paint, which are less hazardous to health and have less odor than solvent-based options. But here, surface preparation is crucial: a fine sanding of the melamine surface (with a special adhesion primer) is mandatory for the paint to stick. After that, you need several coats with sanding in between to achieve the typical “smooth panel” finish. You should also consider drying times, especially with Kallax, since you probably don’t want to be unable to use the furniture for days. Proper ventilation during painting is also important.
If you work with paint, the result should be more durable, especially if you choose matte or satin finishes—glossy paints can show scratches more easily.
I would also like to ask how experienced you are with painting or wrapping, and whether your Kallax is new or used? This affects the decision because the initial condition is crucial. The intended use also matters: Is it planned for a child’s room, living room, or hobby room?
Looking forward to your response!
On the question of "Kallax new color – wrapping or painting better?":
Wrapping offers a quick, clean solution without major craftsmanship effort. High-quality films are resistant to moisture and scratches but should be used cautiously on heavily used surfaces.
Painting requires extensive preparation: sanding, priming, applying multiple paint layers, and allowing drying times. In return, it provides better surface durability and a visually higher-quality, seamless finish.
For Kallax, painting is technically more demanding because the melamine coating must first be treated with a special adhesion primer to ensure the paint adheres. Those planning to paint should also work in well-ventilated, dust-free environments.
The decision should be based on user needs: If it should be quick, reversible, and as uncomplicated as possible, wrapping is sensible. For a long-lasting, high-quality appearance and better scratch resistance, painting is recommended, provided the necessary time and experience are available.
In conclusion: Both methods are practical but differ in effort, quality of results, and durability – your choice should prioritize these criteria.
