ᐅ KALLAX unit corners damaged upon moving in – repair instructions?
Created on: 23 Jul 2022 08:43
Amirmar
I recently moved into a new apartment and noticed some damage to the corners of my KALLAX unit (the shelf with square compartments) while assembling it. The corners are scraped on two sides and have cracks, probably caused during transport or handling during the move. Since I really want to use the unit, I am looking for a practical repair guide on how to best fix these corner damages without significantly affecting the appearance.
Are there established methods you can recommend for repairing corners like this, for example using special fillers, sanding, painting, or even specific repair kits for KALLAX? Is it necessary to replace individual parts, or can such damage be repaired discreetly by myself?
I look forward to your experiences, tips, and suggestions on the best approach so I don’t have to discard the shelf. Many thanks in advance!
Hello Amirmar,
From my own experience, I can say that a combination of wood filler followed by sanding and painting usually works well, but only if the damage is not too extensive. With KALLAX, the melamine coating is the main reason to be very careful when filling and sanding to avoid further damage to the surface.
It is also important to use an acrylic paint for the repair that exactly matches the color of the shelf. Sometimes using paint markers or furniture touch-up pens is worthwhile if the scratches are only minor.
If the damage to the load-bearing edges is severe, you could try reinforcing stability from the inside with small metal or plastic brackets. This also reduces the risk of the corners detaching further.
I hope this helps you with your repair! Feel free to ask if you have any more questions :-)
BAUEVA schrieb:
The surface is often coated with melamine, and this coating sometimes prevents an optimal bond.Exactly. I’ve had experience with that as well.
You definitely need to make sure the surface is lightly roughened with very fine sandpaper before applying filler so the repair material adheres better. But be careful: sanding too aggressively will damage the surface and make it look worse afterward.
I also recommend using an acrylic or synthetic resin paint specifically designed for melamine-coated furniture. Cheap solutions don’t last long—especially for frequently used furniture like KALLAX, where durability and scratch resistance are essential.
GiRoyce schrieb:
With KALLAX, the melamine coating is the main reason why you need to be very careful when filling and sandingThank you for this important tip, I wasn’t fully aware of that. The damage mainly affects the edges and corners, and I’m concerned that the protective layer might be completely gone after the repair.
theo63 schrieb:
You should definitely make sure to lightly roughen the surface with very fine sandpaper before fillingHow fine exactly should the sandpaper be? Is there a specific technique I should use when sanding the corners to avoid chipping or peeling of the surface?
I would also like to know which stores or online shops you recommend for special acrylic or resin-based paints suitable for melamine coatings. I want to avoid buying the wrong products.
It would be great if you could share some concrete tips on this as well – thanks in advance!
