ᐅ KALLAX for Vinyl Collectors – Does It Really Hold Up?
Created on: 21 Jul 2019 19:07
Jafu1
Jafu1
21 Jul 2019 19:07
Hello everyone, I have a question that will probably interest some record collectors here: How suitable is the IKEA KALLAX shelf really for storing a large vinyl collection in an organized and secure way?
I have read that many collectors appreciate the KALLAX because of its simple design and the 33x33 cm (13x13 inches) compartments, which seem perfectly sized for LPs. However, I have some concerns because the shelf is made of particleboard, and I’m not sure how stable it is over a long period when supporting the weight of a large collection. Strangely, there are also reports that the shelf tends to sag when fully loaded and that the edges are not ideally protected.
I am especially interested in hearing from anyone who has used the KALLAX shelf for several years with several hundred records and how sturdy and durable it really is. Or is it ultimately just a somewhat suitable but problematic compromise in the long run, more appealing to design enthusiasts who expand their collection only occasionally?
I look forward to your experiences and assessments!
GALEO4
21 Jul 2019 19:42
Jafu1 schrieb:
I have read that many collectors appreciate the KALLAX because it looks simple and its 33x33 cm (13x13 inches) compartments should be perfectly sized for LPs.
That’s exactly the key point! Simple in appearance also means minimalist, cheap, and ultimately not something serious collectors should want for the long term.
I often see the KALLAX used as a convenient excuse by people who don’t want real collector solutions and prefer quantity and "consumption" over quality and durability. Sure, the compartments fit records perfectly, but the construction uses unstable materials and is definitely designed for office use or DVD collections rather than for heavy vinyl treasures that weigh tons.
Jafu1 schrieb:
The shelf is made of particleboard, and I’m not sure how stable it will remain over time under the weight of an extensive collection.
That’s exactly my criticism! Frankly, the shelf is cheaply made, and yes, it might hold up for a few years, but you’ll quickly start seeing warped shelves and swollen edges. For collectors with passion and sense, there are much better options out there if you look beyond just IKEA.
GLAEL
21 Jul 2019 20:05
KALLAX is fine if you don’t have too many boards. For large collections, you need sturdier shelves with thicker boards. Make sure the shelves don’t sag.
Adding paneling under the shelves or metal supports can help.
Otherwise, it’s okay as a compromise.
LENNAU
22 Jul 2019 07:31
I would like to go into more detail, as handling vinyl storage is not always straightforward. Basically, the IKEA KALLAX shelving unit is visually and dimensionally well-suited for LPs. The internal depth and height of the compartments fit vinyl sleeves very well, which makes the collection look neat and organized.
However, it should be noted that the thickness of the wood and the material used (MDF or particleboard) have a load limit when the shelves are fully loaded with weight. It is common for the shelves to sag over time, especially if the compartments are heavily packed.
To counteract this, it makes sense to reinforce the shelves, for example with metal brackets or by adding wooden strips underneath. Anyone who wants to store their collection permanently and carefully should also consider storing the records upright and avoiding overfilling – by the way, this applies to any shelving unit.
If you use the KALLAX for a medium-sized collection and check it regularly, the unit could definitely be a practical and space-saving solution. For very large or valuable collections, however, I recommend investing in purpose-built shelves made of solid wood or metal frames with sturdy shelves, which better protect the records and ensure the longevity of the collection.
NUPIN
22 Jul 2019 11:17
Hey, I’m really excited about my KALLAX shelf for my vinyl records! 🙂 I have a large collection and find the shelves very practical because you can easily browse through the records.
Of course, you need to be careful not to overload the compartments. But with good organization and being mindful of the thickness, you quickly get a feel for what works.
I added a few MDF panels for reinforcement, and since then everything has been rock solid. I also find the KALLAX very appealing in terms of design and flexible because you can easily rearrange the shelves.
So, I think it’s a great starter option and really sturdy for vinyl collectors who don’t want a display case right away. It would be great if IKEA offered even stronger shelves in the future! But in terms of advantages: top quality!
Edric
23 Jul 2019 09:43
Jafu1 schrieb:
I’m mainly interested in whether anyone has used the KALLAX shelving unit for several years with several hundred records and how stable and durable it really is.
I understand that durability is important to you as your collection grows—that’s something I worry about myself at times. I’ve been using my KALLAX for almost 3 years now, holding about 400 records. At first, I was very satisfied because it’s simple and the records stand well.
However, I’m starting to notice some weaknesses. A few of the shelves have begun to sag slightly, which made me uneasy at first. Luckily, I fixed the units to the wall and added small wooden battens underneath to support the shelves. That improved the stability, and I feel more confident now.
Personally, I don’t see the shelving as a perfect lifelong solution, but rather a reasonable compromise that works well if you regularly maintain it and make small adjustments. For very large or valuable collections, more specialized shelving systems are better.
Proper storage is also important—avoid constant heavy stacks or overfilled compartments. I recommend regularly checking the unit and investing in reinforcements if you plan to use your KALLAX for more than a few years.
