I’m planning to cover my KALLAX shelf with custom decorative films to make it more personal and colorful. I’m particularly interested in how durable and visually appealing these films are, how easy they are to apply, and whether there are any issues when removing them later—such as residue or damage to the wood.
Has anyone had experience using custom decorative films on KALLAX shelves? What type of films did you use (self-printed, ordered, what quality)? It would also be helpful to know how you cut the films and if you can recommend any special techniques or tools to avoid air bubbles or wrinkles.
Thanks in advance for your tips and feedback!
Likolo schrieb:
I plan to decorate my KALLAX shelf with custom vinyl wraps to make it more personal and colorful.Hello Likolo,
I wrapped my KALLAX with custom-designed vinyl wraps about a year ago and can share some experience:
1. Vinyl quality: I used high-quality PVC vinyl from a specialized online printer. It is durable, opaque, and easy to work with.
2. Application: It’s important to clean the surface thoroughly beforehand and remove any dust. I applied the vinyl slowly using a squeegee (a type of plastic spatula) to avoid bubbles. I cut the vinyl precisely with a craft knife on a cutting mat.
3. Durability: After one year, everything still looks great, with no cracks or peeling.
4. Removal: If you want to remove the vinyl later, it usually comes off cleanly, as long as it hasn’t been on for too long (max. 2–3 years).
5. Tip: Consider having the vinyl printed with a matte finish instead of glossy; it looks more elegant and hides fingerprints better.
If you want to know more details, feel free to ask!
Ramon4 schrieb:
If you want to remove the film at some point, it usually comes off without residue, as long as it hasn’t been on too long (max. 2–3 years).Interesting, but honestly: why would anyone want to re-cover a customized KALLAX in the first place? If you decorate a shelf, you probably want it to stay that way forever, right? I find these films to be a widespread change in furniture culture—full of short-lived trends and hardly any sustainable ideas.
Also, what about the environmental impact of these films? Are they recyclable, or is this just a temporary decoration that you could have achieved with much more effort by sanding and painting?
Personally, I would advise against covering a proven shelf entirely with film and instead recommend treating the wood or surface directly. The film is only a superficial solution that ignores more important issues like material quality, indoor air quality, and true sustainability.
What do you all think?
I would like to add a few practical tips since I have already decorated several KALLAX variants with adhesive films. Here are some suggestions for the process:
1. Preparation: As Ramon4 already mentioned, a grease-free and dust-free surface is essential. I use isopropanol for this.
2. Cutting: The best results come from using a metal ruler and a sharp utility knife. I recommend cutting the film slightly larger than needed, applying it, and then carefully trimming the edges with the knife.
3. Removing bubbles: A squeegee works great, and for the final smoothing, I use a credit card with a protective film. You should apply the film slowly, rolling it from one side to the other rather than pressing it on quickly.
4. Tools: A heat gun or even a hairdryer softens the film during application, which is especially helpful around edges and curves to ensure a good fit.
5. Material: Self-adhesive PVC films with plasticizers are ideal. They are durable, flexible, and usually removable without residue.
Finally: There are also films with special protective coatings that are UV-resistant—something to consider if your KALLAX gets a lot of sunlight.
I hope these tips help!
zarlu schrieb:
Why would anyone want to re-cover a custom KALLAX in the first place?The point is that personalization in the furniture market often clashes with sustainability. Still, I see films not just as a trend but also as a form of decoration that can add value to furniture or protect it from external factors.
Guyju schrieb:
There are also films with special protective coatings that are UV-resistant – something to consider if your KALLAX gets a lot of sunlight.That’s an aspect that deserves more attention. Many film manufacturers provide little information about durability and environmental impact, which makes the decision harder.
I think it would be interesting if users also rated how easy the films are to maintain or how well they perform in different environments – for example, a child’s room versus a living room.
What do you think? Would more comparison and shared experiences here help avoid general assumptions?
