ᐅ Corners of Kallax units chipped – how to reinforce them?
Created on: 7 Dec 2022 08:14
LISGAU45
I recently noticed that some of the corners on my Kallax shelving unit have broken off. More specifically, these are the inner edges at the joints between the individual shelf compartments. This loss of stability is frustrating, as it weakens the unit and affects its appearance.
My question is: What is the best way to reinforce these broken Kallax corners? Are there practical and discreet repair methods that will hold up over time? It is important to me to avoid fully disassembling the shelf or doing major modifications. A solution using readily available materials would be ideal.
I would appreciate any advice on repair materials, techniques, or sustainable reinforcements!
Jukin
8 Dec 2022 08:20
If you are using brackets for stabilization, make sure the screws bite properly and do not just hold in the thin plywood layer.
Sometimes it can help to fill the screw holes with wood glue, insert a small piece of wood, and then drive in the screw—for better grip.
Attaching small cross battens on the inside edges can also improve stability.
The principle here is: often you can achieve a lot with a little material.
Hector
8 Dec 2022 10:05
Wesley schrieb:
Kallax is basically a cool modular system, but it is also prone to weaknesses at the joints
For further discussion:
It should not be forgotten that the Kallax shelf is not originally designed to handle high loads at the connection points. The material thickness is low, and chipboard behaves mechanically differently from solid wood.
Therefore, mechanical reinforcements should be chosen carefully. For heavy loads, I recommend additional support, for example by placing supports under the shelves or doubling the panels.
It remains questionable whether repairs while the unit is installed are always the best option – sometimes disassembling and reassembling is the better approach.
LISGAU45
8 Dec 2022 13:50
Thanks to everyone for the valuable feedback.
The main issue seems to be the combination of proper gluing, mechanical reinforcement using wooden strips or metal brackets, and appropriate screwing—possibly with additional reinforcements attached at the back.
My next step will be to fill the damaged corners with wooden strips and secure them with wood glue and screws, pre-drilling the screw holes beforehand and then adding small brackets to distribute the load.
The back panel is still fine, but I will keep that in mind.
If anyone has experience with long-lasting aesthetic surface lamination for repairs, I’d appreciate any tips. 🙂
