Hello everyone, I have a problem with my Ikea Malm nightstands, which start to feel wobbly after some time. Since I’m looking for a durable and secure solution, I’m especially interested in how to effectively and permanently improve the stability of these nightstands—not just a quick repair, but a long-term reinforcement of the structure. What measures are particularly suitable to stabilize the cabinet edges, strengthen the joints between the components, and generally make the nightstand more resistant to wobbling or warping? Are there any proven methods or material recommendations that you use in practice? Thanks in advance!
Hello elisabet38,
Regarding your question: Installing metal brackets and wooden battens can significantly improve stability. It is important to be very precise during installation:
- Best to attach metal brackets at the corners using short but strong screws that penetrate deeply into the wood.
- Make sure the bracket screws are not placed too close to the edges to prevent the wood from splitting.
- Keep internal battens as slim as possible and support them with wood glue.
A combination of wood glue, additional screws, and reinforcements ensures lasting structural integrity. The wood can bear more load when it is evenly supported rather than stressed at isolated points.
I also recommend checking the back panel: A securely fixed plywood back panel with extra battens further strengthens the whole structure.
Taylorsi4520 Jun 2020 12:45For fastening: Pre-drilling is essential to prevent the wood from splitting. Interior angles should be installed so they are not visible from the outside. Use short screws that are just long enough to hold securely.
I wonder if the problem also lies in the design of the Malm model itself. After all, it is an inexpensive piece of furniture that is not designed to bear heavy loads.
Perhaps it would be more sensible to reconsider the intended use of the nightstands before investing a lot of effort. For someone with higher loads (e.g., many devices on it or heavier decorations), in my opinion, it is better to choose a more sturdy piece of furniture.
I agree with that, but the choice of material must not be overlooked.
KUDAISY schrieb:
A combination of wood glue, additional screws, and reinforcements achieves a lasting structural stability.
elisabet3820 Jun 2020 15:33@BLAKEO You raised an important point, thank you! So it’s about finding a compromise between furniture weight, functionality, and durability, right? For me, the main focus is on a practical, affordable solution. I deliberately chose Malm and don’t necessarily want to switch to a different model if I can stabilize it with appropriate reinforcements.
In the meantime, I’ve been wondering whether a combination of metal brackets inside, wooden strips, and glue-reinforced joints is truly the best approach. How much can the risk of material fatigue increase at the points where such interventions are made?
BLAKEO schrieb:
After all, it’s an inexpensive piece of furniture not designed for heavy loads.That’s true, BLAKEO, but for everyday use, simple furniture like Malm is fine if properly maintained and reinforced.
elisabet38 schrieb:
How much does the risk of material fatigue increase at the points where modifications are made?If you pre-drill and use screws of suitable quality, material fatigue in the wood is generally low. Wood is meant to be assembled. Damage occurs with improper installation or screws that are too large, that’s correct. So it’s better to prepare carefully than to apply excessive force.
A few points to consider:
1. Wood glue permanently increases stability, provided the surfaces are clean and smooth. Old glue should be removed.
2. If screw holes are worn out, wooden dowels or wood filler can help – the latter only if the load is not heavy.
3. Metal brackets are useful, not just for corners but also place them in the middle as cross braces.
4. The back panel plays a crucial role. If it’s just thin cardboard, I recommend replacing it with real plywood panels of similar thickness. This way, you can make the nightstand more stable, like a box.
5. When choosing screws: For particleboard material, it’s better to use special particleboard screws.
6. Last but not least: If you plan to put more weight on the nightstand, include additional reinforcements.
