ᐅ KALLAX Shelving and Heavy Files – How to Secure Them Safely?
Created on: 8 Jan 2017 08:17
Joelro
Joelro
8 Jan 2017 08:17
I currently have a problem with wanting to store some very heavy file folders in my IKEA KALLAX shelf. These folders are not only full but also quite old and heavy in some cases. Now I’m concerned whether the shelves can support the weight long-term or if they might bend or even break.
Does anyone have experience with reinforcing the KALLAX shelf for heavy files? Are there special reinforcements, additional supports, or other tips to make the shelf suitable for high loads?
I would appreciate any advice so I don’t have to worry about the whole load being stored there.
JAMESONB41
8 Jan 2017 09:42
I would recommend reinforcing the shelves with a plywood board. This significantly increases the load-bearing capacity.
Alternatively, metal brackets can be screwed under the shelves, which is especially helpful for heavy loads.
tuFernando
8 Jan 2017 11:35
Joelro schrieb:
Does anyone have experience on how to best secure the KALLAX shelf for heavy files?
I completely understand your concern; it’s understandable to worry when dealing with valuable and heavy files. I had the same issue once – I simply reinforced the back panel with wooden slats and supported the shelves with thin metal brackets.
That felt like a good solution to me to prevent any sagging. What also gave me peace of mind was regular inspection – so occasionally checking to see if anything had shifted.
You’re not alone with this question; I’m sure many here are familiar with this challenge!
popodi
9 Jan 2017 07:53
Hi Joelro,
if you’re storing heavy files, a bit of extra reinforcement is always a good idea. I used a few small tricks with my KALLAX: wooden slats for strengthening, yes, but also felt or rubber pads placed at contact points to prevent slipping or rubbing.
To prevent sagging, I also added a beam across the shelf – basically an invisible stabilizer :-) This not only improves stability but almost looks intentional.
Better to be safe than sorry, otherwise you might end up with a sad KALLAX story someday ;-)
Lucki
9 Jan 2017 12:14
Joelro schrieb:
Are there any special reinforcements, additional brackets, or other tricks to make the shelf suitable for heavy loads?
Great topic, I love it when things get detailed! 🙂 I once had a similar setup – my shelves were nearly sagging under piles of files. My trick was a combination of simple wooden reinforcements and clamp braces during assembly to make everything rock solid.
Also: don’t overload all compartments equally; spreading the weight helps. Especially with KALLAX shelves, you quickly notice if you put too much weight on a single compartment.
So: wood reinforcement + smart weight distribution = problem solved! Good luck, you’ll manage it easily!
