ᐅ Is it possible to assemble IKEA PAX without professional help?
Created on: 30 Aug 2020 19:27
prablaIs it possible to assemble the IKEA PAX wardrobe without professional help?
I’m planning to get the PAX wardrobe soon, but I’m unsure if I can manage the assembly on my own. The instructions seem detailed, but with such a large piece of furniture, I’m not sure if it’s really doable without professionals. What experiences have you had? Is it advisable to have someone with experience help, or can you really handle it independently with some basic DIY skills? Are there any tips or tricks that make the assembly easier?
I’m looking forward to your assessments and practical experiences, especially from those who have put together the PAX without external assistance.
I completely understand your uncertainty, prabla.
I had my doubts as well when assembling my PAX. It really has a lot of parts, and the instructions can seem overwhelming at first. But with patience and a systematic approach, it’s doable—I managed to do it alone. The most important thing is to take your time, avoid rushing, and proceed step by step.
If you feel unsure, having a second person can be very helpful, especially to hold heavy parts or assist with adjustments. However, it’s not absolutely necessary. I would also recommend sorting all the parts beforehand and reading the instructions carefully before you start.
Do you have experience with other flatpack furniture? That often helps to better understand the process.
prabla schrieb:
Is it advisable to have someone with experience help out, or can you manage it on your own with some basic DIY skills?
Great question, prabla!!!
I really like the PAX, and yes: You can definitely assemble it on your own!!! 😃👍 I put mine together a few months ago without any professional help, and it worked out great. Of course, it takes some time and patience, but that’s not a problem at all.
Here are a few tips to make things easier for you:
- Plan enough time, preferably spread over two days.
- Find some motivating music to keep you going! 😉
- Use a cordless drill; it saves a lot of effort.
- First, loosely screw in each screw, then tighten them at the end.
- Keep all parts and screws well organized and ready.
And one more thing: if you’re not sure, just invite a friend to help. It’s actually a lot of fun and often the best motivation!
Good luck, you’ve got this!!!
prabla schrieb:
Is it possible to assemble IKEA PAX without professional help?Yes, assembling the IKEA PAX system is generally possible without professional assistance. Here are some practical points that can help:
- The PAX furniture is modular, which keeps the individual components manageable.
- The included instructions are detailed; however, it is advisable to first check and sort all parts completely.
- Using a cordless drill with a torque limiter is recommended to avoid over-tightening screws.
- Depending on the size of the wardrobe, it might be necessary to have help when lifting and adjusting it, which is advisable for ergonomic reasons.
- Allow about 3–4 hours to complete the assembly, depending on your experience.
- Replacement parts and options to purchase additional components are readily available if mistakes occur during assembly.
In summary: With a disciplined and organized approach, it is possible to assemble the PAX system independently. This is not a professional installation, but one should be realistic regarding physical strength and patience.
For special customizations or more complex built-in systems, hiring a professional can be considered but is not strictly necessary.
Henry schrieb:
If you’re unsure, having a second person can be very helpful, especially to hold heavy parts or assist with adjustments.I can only confirm that. At first, I was quite intimidated by the assembly, because the instructions can be confusing in places. But working together with a friend made it manageable. You don’t necessarily need a professional, but having someone to think along and help is invaluable.
I also learned not to rush ahead, but to check each part multiple times before tightening the screws. In the end, the cabinet really made me proud – it’s definitely worth taking the time and accepting the challenge.
So: yes, it is absolutely doable, just don’t be afraid!
