ᐅ Is there a practical guide for assembling Ikea BESTA without the official instructions?
Created on: 28 Mar 2021 08:37
O
onteo
I am facing the following problem: I have purchased an Ikea Besta shelving unit but no longer have the assembly instructions. Is there a practical, reliable guide or a systematic approach to assembling the Besta cabinet correctly and without major mistakes, even without the official instructions? I am particularly interested in tips for identifying the individual components, the correct assembly sequence, and possible pitfalls to avoid. I want to proceed as efficiently as possible and avoid unnecessary disassembly since I am not an experienced DIYer. Does anyone have experience or can recommend a kind of step-by-step guide that works without the official IKEA manual?
Lorukeo
28 Mar 2021 14:00
Due to Besta’s modular construction method, it is truly advantageous to proceed systematically. The first step is to lay out all components as flat as possible and sort them into categories: side panels, bases, back panels, fronts, and connecting elements separately. Side panels usually have upper and lower drill holes that align with the base plates. The back panels are often only held in place with clips, which is done last. I recommend using tools such as a protractor and a cordless drill with a depth stop. Another tip is to loosely assemble the parts during each screwing step to allow for adjustments before everything is finally secured.
pinDavid
28 Mar 2021 14:12
Short and precise: Sort all parts first, assemble the frame structure initially. Attach the back panel last. Tighten screws only loosely. Use the existing drill holes as a guide.
JORDON
29 Mar 2021 08:09
So, assembling the BESTA cabinet without instructions? No problem at all! Just remember: IKEA designed it to be intuitive and straightforward. As long as you’re sure which part is front and back and don’t start screwing pieces together randomly, you’ll manage it easily. A little tip: do it with some relaxing music and a coffee nearby — it makes the process twice as enjoyable 😄. And don’t worry if something gets tricky along the way, that’s completely normal! Good luck!
elgla
29 Mar 2021 10:14
I understand that not having the instructions can be quite stressful. I had a similar experience with another IKEA piece of furniture, and I only managed it by going step by step and taking plenty of breaks. The most important thing is not to rush and to double-check if you’re unsure before screwing anything together. It can also help to carefully look over the individual parts before assembly to get a feel for how they fit. If you like, we can share how things are going for you here.
jeff65
29 Mar 2021 11:03
onteo schrieb:
Are there users who have managed a smooth assembly through systematic approach and good knowledge of the components without official instructions?
In my experience, users with technical understanding who are willing to engage with the structure of the components can indeed assemble the BESTA shelving unit correctly even without official instructions. This mainly requires careful observation of the pre-drilled holes and some patience regarding the sequence of steps. If you like, I can prepare a written outline of the typical assembly steps for you.
Pome60
30 Mar 2021 07:33
Great to see so many constructive tips coming together here! My advice to avoid confusion: as soon as you assemble the rough structure, take photos of each step along the way. This way, you can compare them and spot any mistakes earlier. I also made a schedule back then to avoid working for too long at once, because it’s easy to lose track otherwise. Very important: don’t get discouraged, the construction is a rewarding challenge!
