ᐅ Is there a guide for IKEA Brimnes furniture using alternative materials?
Created on: 7 Aug 2020 08:37
Ixonli
Ixonli
7 Aug 2020 08:37
I recently purchased some IKEA Brimnes furniture and am interested in whether there is an official or community-developed guide that describes assembly using alternative materials.
I am not referring to simply replacing screws or dowels, but rather the use of different materials, possibly sustainable or more durable wood, metal braces, or similar, to make the furniture more stable or long-lasting.
Is there anything like this available in written form or as a well-documented project? I want to know before assembly which modifications are feasible without compromising the product’s integrity, so I am looking for a detailed guide or at least proven advice.
Thank you for your insights and suggestions!
NoValentin
7 Aug 2020 09:03
Hello Ixonli,
As far as I know, there is no official guide from IKEA for the Brimnes using alternative materials.
The only thing I can recommend is to check DIY websites and forums, where you can sometimes find user reports with modifications.
However, there is no standardized instruction.
NOAHSAU
7 Aug 2020 10:14
I find it somewhat questionable to modify the Brimnes or other IKEA furniture using "alternative materials."
Ixonli schrieb:
Is there any written documentation or a well-documented project on this? I want to know before assembly which modifications are possible without compromising the product’s integrity.
Who can guarantee that this won’t cause more harm than good? Often, the constructions are designed specifically for the materials used—changing them could actually reduce stability. Maybe this is just an idea born from wishful thinking.
Genevieve
7 Aug 2020 11:22
Interesting point from NOAHSAU, but I believe the topic is definitely relevant.
NOAHSAU schrieb:
Who guarantees that this won't cause more harm than good?
That is a valid concern. This is precisely why a guide based on reliable tests or at least proven experience would be helpful. Simply making changes on a whim can be risky.
I am especially interested in which alternative materials the community has rated as sensible and safe, and whether there are any documented implementations.
Timofa
7 Aug 2020 12:45
I like the idea of upgrading furniture! 😊
With Brimnes, I think you can start with a few simple tricks, such as using MDF instead of particleboard, or replacing the back panel with thin plywood for better stability. Metal brackets instead of plastic connectors can also help sometimes.
However, clear building plans are often missing, so you have to experiment and tinker a bit – that’s why a guide would really be invaluable!
TRA33
7 Aug 2020 14:02
So far, I am not aware of any documented instructions for Brimnes using different materials.
If you plan to replace parts, you should take exact measurements and ensure the same load capacity.
DIY modifications are mostly found as individual reports, but there is no established guide.
