ᐅ Is it possible to have the base cabinet even lower?
Created on: 2 Feb 2016 16:52
Joschka
Joschka
2 Feb 2016 16:52
Is it possible to build a base cabinet with a height of only 86.5 cm (34 inches) plus the countertop? The standard height is usually 80 cm (31.5 inches) plus an 8 cm (3 inches) plinth.
Can the legs be adjusted to a smaller size and the plinth modified, or are the given dimensions fixed and not adjustable?
Thank you very much for your help!
Schmidti82
2 Feb 2016 17:33
the minimum height is 7cm (3 inches),
wolf2000
2 Feb 2016 20:11
No problem at all – I have now partly installed the kitchen on 5cm (2 inches) high legs. You can’t use the standard kickboard from Ikea in that case. Check it out here https://www.hausbau-forum.de/threads/metod-einbau-fragen.21082/
Regards, Wolfgang
Joschka
3 Feb 2016 14:50
Thank you for the link to the lower feet!
That’s how we will do it, so the kitchen window can open as well!
wolf2000
3 Feb 2016 16:50
Here you go, the kitchen window was also the critical point for us....
One more tip about the baseboards: Home improvement stores also offer lower baseboards. I installed the front legs with the "flat" side facing forward, then pre-drilled the baseboards and screwed them into the plastic of the legs. It holds perfectly, and the screw heads are no longer visible afterwards.
