ᐅ Is a soundproof door necessary for the utility room? Any experiences?
Created on: 22 Jul 2018 12:21
Skyfire
Our builder has offered us a soundproof door from Hörmann, climate class III / sound insulation class 2 (RwP 37 dB).
We have an internally installed air-to-water heat pump, controlled mechanical ventilation with heat recovery in the utility room, and otherwise the usual installations including a washer/dryer.
Is a soundproof door necessary or useful in this case? It would cost us an additional 200 euros compared to a standard door.
What about the controlled mechanical ventilation with such a door? Would the air be able to circulate, or would the ventilation be affected?
What do you think?
Thank you
Regards
Sky
What do you think?
Thank you
Regards
Sky
Because this door apparently includes a perimeter seal, if I understand correctly. And if the door is cut slightly shorter at the bottom to allow air to flow from the hallway to the utility room, then these two requirements conflict.
Therefore, either you shorten it enough so that the seal at the bottom no longer functions, or you don’t cut it, but then the airflow will not work.
By the way, we have new Miele washing machine and dryer, and even though we didn’t choose the cheapest models, you can still hear these appliances. In my opinion, a soundproof door definitely makes sense. We also have a controlled mechanical ventilation system, and the door’s seal certainly helps reduce airflow between rooms. However, someone often goes into the utility room, so I don’t see any issues with that since the door isn’t closed all day. I would definitely install a soundproof door again—it’s amazing how much quieter it makes the space.
Sabine
Sabine
