Is a buffer tank generally a worthwhile investment for a heat pump? Or is it highly recommended or even essential?
Is a buffer tank in my case a worthwhile investment? Or is it highly recommended or even essential?
My configuration is:
170 sqm (1829 sq ft) heated area
Energy standard: nearly KfW-55
Ground source heat pump, 3-12 kW modulating
Optimal heat pump size according to calculation: 8 kW
5 household members
Mainz
5 household members
Mainz
jens.knoedel16 Feb 2024 13:03Rübe1 schrieb:
Maybe I missed it, but is it really mandatory to repair it?The compressor is broken and therefore there is no heating system (at most an electric heating element).jens.knoedel schrieb:
The compressor is broken and therefore there is no heating (at most an electric heating element). The electric heating element works only moderately. The hot water temperature is 32°C (90°F).
That electric heating element is supposed to keep the system running at least, is there something else wrong?
Anyway, replacing it takes two people about 1.5 days if they know what they’re doing. It also depends on the region you’re in and how particular the plumbers are at the moment.
In your case, I would choose a different setup: a heat pump as a standalone unit, with a 280-liter (74 gallons) domestic hot water tank, and that’s it. In a single-family home, you usually have enough flow rate, so you typically don’t need to worry about that.
Cost-wise: I replaced an air source heat pump about six months ago, the costs are similar. It was all-in, 18,000 including tax. Whether you can manage with a 4 kW pump needs to be calculated precisely, since that one is quite a bit cheaper.
jens.knoedel16 Feb 2024 15:13jx7 schrieb:
Seasonal performance factor: 4.6Rübe1 schrieb:
Hmm, on closer inspection, one might conclude that a new heat pump increases efficiency,Phew, that’s going to be difficult...I don’t see how that could be seriously justified.
WilderSueden16 Feb 2024 19:18Rübe1 schrieb:
Whether a 4kW heat pump will be sufficient needs to be calculated precisely; they are considerably cheaper, after all.For the area, 4kW heating capacity is definitely not enough. He himself mentions a heating demand of 7-8kW.Otherwise, I think it’s reasonable to adjust the control system during transitional seasons and to turn off the heating for a few days during a sudden spring warm spell like this week. With daytime temperatures of 13-15°C (55-59°F) and significant solar gains, the heating demand is so low that every heat pump cycles frequently.
