ᐅ Installing an interior windowsill: what preparations are necessary?
Created on: 5 Dec 2020 10:10
kuruemeru
kuruemeru
5 Dec 2020 10:10
We have completely replaced our facade. Previously, it consisted only of wood, thin wooden panels, and wooden windows. New windows have now been installed, and the facade has been reinforced. On the outside, an aluminum window sill was added and supported with mortar, which is not even fully sealed. There is quite a bit of air coming through. 🙄
We now want to install interior window sills made of stone.
Currently, a wooden strip is placed on top of the masonry, and beneath the window, the bare stone with holes is still visible.
What precautions should be taken?
I think just filling the gaps with foam would be the wrong approach. Should insulation, for example XPS (extruded polystyrene), be glued here? Can the window sill then be bonded directly, or is more work necessary? I want to avoid thermal bridges and mold formation.
I would appreciate your advice.
Fensterrahmen und Innenraumunterkante; draußen Häuser mit roten Backsteinfassaden und Balkonen.
Spalt unter einer weißen Verkleidung mit Erde und Steine sichtbar; Holzboden im Vordergrund.
Zementboden mit Rissen und zwei runden Löchern unter einer weißen Wandverkleidung.
Nahaufnahme eines horizontalen Fensterrahmens mit weißem Paneel und dunkler Unterkante
Unklarer, unscharfer Blick auf einen schmalen Spalt mit Licht dahinter; daneben glatte Oberflächen
U
user-d29
5 Dec 2020 11:10
kuruemeru schrieb:
There’s a lot of air leaking through here. 🙄
OMG
Did you install this yourself? That’s just not acceptable.
kuruemeru schrieb:
I want to avoid thermal bridges and mold growth.
Then the windows should have been installed properly in the first place.
I have no idea how this can be fixed. If air is coming in, moisture is bound to follow soon.
kuruemeru
5 Dec 2020 11:40
No, I don’t do that myself. It was done by a window installer and a mason. I also don’t think it’s ideal, but I trusted the craftsmanship here.
What would have been the right way to do it?
U
user-d29
5 Dec 2020 12:28
kuruemeru schrieb:
What would have been done correctly?
Try searching for RAL installation, airtightness, driving rain resistance, proper window installation, or similar terms. Then you will see how a proper installation looks. What you have is poor workmanship.
kuruemeru
5 Dec 2020 12:54
The problem is that after the wall frame was installed, the windows were placed in front of the lower wall. I know that the sides were properly sealed with sealing tape. The mason then filled in underneath with mortar, which looks rather untidy and certainly does not comply with RAL standards. But the damage is done, and I need a solution that doesn’t involve ripping everything out. Surely it should be possible to fix this afterwards using sealing tape, foam insulation, or insulation panels to correct the issue to a satisfactory extent.
kuruemeru
5 Dec 2020 12:57
If necessary, remove the mortar below the windows and replace it with something appropriate. But before proceeding incorrectly, I wanted to ask first.
