ᐅ Ikea Veddinge white, missing end panels and baseboard / skirting boards
Created on: 27 May 2015 09:38
kleinho
kleinho
27 May 2015 09:38
Good morning,
we are interested in the Veddinge kitchen fronts in white. However, there are no matching white end panels longer than 60cm (24 inches). Also, the toe kick is only available in gray. Has anyone encountered this issue and how was it solved?
IKEA-Experte
27 May 2015 12:55
Hello, these are available as Förbättra deck panels (white and ivory white).
kleinho
27 May 2015 18:57
Hello Ikea expert,
Thank you for your reply. The Nodsta top surface seems to me to be of higher quality. Does it have the same color as Veddinge? At first glance, I cannot see any difference in color.
IKEA-Experte
28 May 2015 13:37
Hello, you need to compare the colors in their original form. The display on a monitor is always distorted. The surface textures are different. This alone will be noticeable, even if the shade is supposed to be the same.
berliner_123
12 Jul 2015 13:11
I have a similar problem. Did FÖRBÄTTRA white work for you?
We have Veddinge white fronts, but Veddinge toe kicks and panels are only available in gray (why is that)? What did you use as a white alternative?
In our corner, where material differences in white would be more noticeable, we could simply take an 80x40 cm (32x16 inches) Veddinge white drawer front and have it cut for the panels. But for the toe kicks, it’s difficult since I need lengths of 220 cm (87 inches)...
Thanks.
