ᐅ Ikea Metod: How do I fix loose screws in cabinets?
Created on: 31 May 2019 14:07
gabau
gabau
31 May 2019 14:07
I have noticed that some screws inside my Ikea Metod kitchen cabinet feel quite loose or slightly wobbly. This causes the cabinet doors not to close firmly anymore and makes the whole unit seem unstable. I suspect this is due to regular everyday opening and closing, but it might also be related to the cam fittings or the materials used, which could contribute to the issue.
So my question is: What is the best way to fix these loose screws in Ikea Metod cabinets without having to dismantle the entire piece of furniture? What steps do you recommend? Are there any special tools or handy tricks to make the screws hold properly again? And what should be considered with the different types of screws (e.g., particleboard screws, cam lock screws)?
I look forward to your detailed tips and experiences, thank you in advance!
Laukau5
31 May 2019 17:36
Hello gabau,
Your issue with loose screws in Ikea Metod cabinets is quite common. Here is a detailed approach to the repair:
1. First, identify the type of screws precisely: Metod cabinets mostly use particleboard screws that are driven into pre-drilled holes, sometimes connected with cam fittings.
2. Loosen the screws: It is generally recommended to carefully remove the screw completely to inspect the area.
3. Cavities and loose material in the drilled hole are often the cause of poor grip. You can fill the holes with wood glue and wood shavings or small wooden wedges. Alternatively, special furniture repair kits designed to fill stripped holes can also be used.
4. After drying, reinsert the screw, ideally using a screwdriver that exactly fits the screw head to avoid further damage.
5. For cam fittings, it can help to slightly tighten the cams and check if the connecting fittings are bent or damaged.
A small tip: If the holes are already too worn out, inserting cedar wood shims or small wooden strips can provide better grip for the screw.
I would be interested to know if the screws are loose in the back panel, side parts, or on the fittings? That might change the repair method slightly.
Best regards!
SUBEN60
1 Jun 2019 08:52
Laukau5 schrieb:
Here you can fill the drill holes with wood glue and wood shavings or small wooden wedges.
This is a proven method when screws loosen in chipboard or wood-based panels. However, with Ikea Metod, the following points should also be considered:
- Use screws and fittings that are original Ikea parts, as their dimensions and materials are precisely matched to the system.
- For damaged or frayed holes, it is also recommended to insert dowels or wood fiber inserts to increase load-bearing capacity.
- Be careful not to tighten the screws too much, as this can damage the material. Having a feel for the correct torque is helpful.
- For added security, small washers can be used to adapt the screw heads.
Regarding tool recommendations: A cordless drill with adjustable torque is convenient but often not ideal for fine furniture work. A sturdy screwdriver with a well-gripping blade is better for controlled handling.
About screw types: Chipboard screws bite into the workpiece, cam lock systems connect furniture parts and are turned via the cams. The cams are often loosened with Phillips screwdrivers or special bits.
In conclusion: The repair requires some patience and precision, but with the right approach, these issues can usually be resolved permanently.
Henry
1 Jun 2019 20:23
I really appreciate that you described the problem so clearly and in detail, gabau. I had the same issue with my Metod cabinet, and I first hesitated whether to try to fix it myself or contact customer service.
gabau schrieb:
What is the best way to fix these loose screws in Ikea Metod cabinets without having to take the entire piece of furniture apart?
From my experience, it helps to carefully unscrew the affected screws first, then fill the holes with coarse wood shavings mixed with some wood glue, and let it cure properly – I left it to dry for several days. You can also improvise with toothpicks if you don’t have wood shavings available.
It’s also important, after it has cured, to avoid over-tightening the screws—instead, turn them slightly counterclockwise if they feel stuck. This protects the material.
If you notice that the wood around the hole is very crumbly, I would recommend using a larger screw or even a repair kit with wooden dowels.
I understand this is not the most elegant solution, but for me, it firmly restored the cabinet while preserving its original assembly.
Good luck with your repair!
JAPLO
2 Jun 2019 10:14
Henry schrieb:
If you notice that the wood around the hole is already very brittle, I would rather recommend using a larger screw or even a repair kit with wooden dowels.
I agree with this. Additionally, I suggest checking the exact location of the screws before starting any repair:
- If they are load-bearing joints, proceed with extra care.
- If screws on the back of doors are loose, sometimes replacing them with slightly longer original screws can help achieve better grip.
Also keep in mind that Ikea Metod cabinets often use cam lock fasteners, which tighten with a small turn. It’s useful to inspect these cams for damage and replace them if needed instead of just retightening the screws.
If these cams are damaged, you can quickly lose holding strength even if the screw seems tight.
One last tip: especially in kitchens and damp rooms, be careful not to use excessive force with cordless drills to avoid material breakage.
Get well with your cabinet!
