ᐅ Step-by-step Guide to Installing Soft-Close Drawers with the Ikea Metod System
Created on: 30 Jan 2020 19:32
HORST50Hello everyone,
I recently bought an Ikea Metod kitchen unit and now want to install the soft-close drawers. However, I am not entirely sure about some of the installation steps and want to avoid damaging the soft-close mechanism or having the drawers not close properly due to incorrect assembly.
Specifically, I would like to know:
- How exactly are the drawer slides mounted with Metod?
- Are there any special tips for aligning the soft-close components?
- What sequence should I follow to ensure everything works smoothly?
- Are there common mistakes during installation that I should avoid?
I do have the assembly instructions, but I find them partly confusing, especially regarding the fine adjustment of the damping. Who can guide me step by step or clearly and practically explain the entire installation process? Thanks in advance for your support!
Hello Horst50,
I completely understand your question. Installing the soft-close drawers in the Ikea Metod system isn’t very complicated, but a few details make all the difference.
Here is a step-by-step guide on how I did it:
- First, mount the drawer slides (Metod drawer runner) to the cabinet frame. It is important to attach them exactly at the same height and parallel, usually measured 37 mm (1.5 inches) from the bottom of the cabinet.
- Then click the soft-close damping mechanism (usually pre-assembled) onto the rail.
- Next, prepare the drawer: attach the side rails to the drawer itself. Be careful, there are upper and lower mounting points that need to be precisely aligned.
- Carefully slide the drawer onto the cabinet until you hear a click – this locks the drawer into the runner.
- For fine adjustment, you can slightly loosen the rear screws and adjust the drawer’s height and depth.
Common mistakes include a crooked cabinet frame or drawer slides not mounted at the same height, which causes the drawer to stick. If you ignore the instructions for aligning the screws a bit and rely on hearing the click, you should be on the safe side.
If you want, I can explain any steps in more detail. Good luck!
to respond precisely to Horst50’s question:
- Installation of the drawer slides: The rails are attached to the side walls of the Metod cabinet frame using the included screws. Make sure to align the front edge of the rail flush with the cabinet front.
- Soft-close mechanism: This is usually already integrated into the Metod drawer slides. Check that the damper is properly engaged before inserting the drawer.
- Sequence: 1) Install the rails on the cabinet frame, 2) Attach the rails to the drawer, 3) Insert the drawer into the rails, 4) Adjust for a perfect fit.
- Common issues: Incorrect mounting of the rails (not parallel, varying heights), screws not tightened enough, incorrect insertion of the drawer.
For fine adjustment, you can slightly loosen the screws on the drawer and vary its position.
This fine adjustment is especially worthwhile for large drawers to ensure even closing. Tip: Pay attention to the labels in the instructions indicating left/right sides to avoid confusion.
JEREMIAH3831 Jan 2020 12:03HORST50 schrieb:
I do have the installation manual, but I find it partly confusing, especially regarding the fine adjustment of the damping.I know that feeling well, with an installation manual that’s more for a quick overview than for detailed guidance.
I had similar issues when installing the soft-close drawers in my Metod kitchen. The most frustrating moment is when you realize the drawer doesn’t close properly or feels too stiff.
My advice:
- Take your time with the adjustment; it’s not unusual to realign the screws on the drawer or the sliding rails two or three times.
- Also check the position of the damping mechanism – it should move smoothly without sticking.
- If the drawer is very hard to operate, it could be due to incorrectly installed slides or the soft-close components not being fully engaged.
In the end, patience and careful trial-and-error got me there. It also helped to remove the drawer completely and double-check all connections – small misalignments are often overlooked.
Good luck! You can do it.
Kyler10 schrieb:
Especially with large drawers, this fine adjustment is worthwhile to ensure smooth and even closing.I completely agree with Kyler10 – the fine adjustment really makes all the difference! 😀
I also learned during my last kitchen renovation: Soft-close is like good coffee – the small details give you the perfect experience, or in this case, the perfect closing of the drawer.
A little extra tip from me:
- If the drawer rattles or makes noise at the end, check the plastic stoppers on the drawer slides. Sometimes they’re not positioned correctly, which causes annoying noise when opening and closing.
- The adjustment screws for height and depth might be tricky, but they are very effective. Just turn, test, and enjoy!
I know the manual can sometimes feel like abstract reading, but with a bit of fun screwing around, it’s really worth the effort. You’ll soon enjoy your squeak-free, smoothly gliding drawers 🎉
