ᐅ Ikea Besta doors not flush – is this a defect?
Created on: 15 May 2015 19:19
Stevo
Stevo
15 May 2015 19:19
After assembling a Besta cabinet, I’m not sure if the door is improperly installed due to my mistakes, or if the door panel itself is defective.
Here is a photo of the current result:
Close-up of white cabinet fronts in interior finishing, wooden floor visible
There are two drawers installed at the top and two doors at the bottom.
The problem is with the bottom right door, as you can see more clearly here:
White modern base cabinet with drawers and door fronts on wooden floor
The door is only misaligned at the upper left corner. That means this corner protrudes further into the cabinet interior than the bottom door. To me, it looks like the door itself is warped or twisted.
Does anyone have any tips on how to adjust the door so it looks right, or do you think an exchange is necessary?
Thanks in advance for your feedback!
Stevo
IKEA-Experte
16 May 2015 19:01
from the picture, it is not clear that the right door is inset further at the upper left corner. Logically, a deeper inset means the door contacts the cabinet at the upper left corner but not at the bottom. Otherwise, everything else would be incorrect.
So the first check should be whether all the door stops are installed and where the doors contact the cabinet and where they do not.
