ᐅ How often should Ikea Brimnes furniture be tightened or maintained?
Created on: 9 Feb 2023 19:23
U
ulyssespu
U
ulyssespu
9 Feb 2023 19:23
Hello everyone, I have a question that might be interesting for some of you: How often should screws and connections on Ikea Brimnes furniture be tightened or generally maintained?
I own a Brimnes bed and a sideboard myself, and I noticed that after some time, everything feels a bit wobbly. I assume that after a certain period of use, some connections should be secured, but how long is that advisable?
Maybe it also depends on how intensively the furniture is used, but I would like to get a rough guideline or recommendation so I don’t have to do it too early or too late. Are there any specific tips regarding the screws or types of connectors that Ikea uses for Brimnes?
Thanks in advance for your experiences and advice!
Jensson
9 Feb 2023 20:05
Hello ulyssespu,
Regarding your question: How often should screws and joints be tightened or maintained on Ikea Brimnes furniture?
I have some Brimnes pieces myself, and from experience, it makes sense to tighten the screws after assembly and then regularly afterwards – ideally:
- Right after the first week of use, as the wood and joints tend to settle initially
- Then every 3 to 6 months, depending on how much the furniture is used
Ikea often uses so-called Minifix connectors and wooden dowels in Brimnes furniture. Especially Minifix connectors tend to loosen with movement. It is important to tighten them evenly to avoid excessive stress on individual parts and prevent damage to the material.
I also recommend:
- Always check before tightening if any parts have warped
- Avoid overtightening screws, as the particleboard can tear
In summary: Tightening every few months is advisable. If you skip this, you risk wobbly furniture or damage that can be more difficult to repair over time.
If you like, I can also describe how to best check and tighten the Minifix connectors.
gasidney
9 Feb 2023 20:47
Tightening every 3 to 6 months is usually sufficient. For wobbly furniture, check the screws immediately.
Dilen
10 Feb 2023 08:33
Jensson schrieb:
IKEA often uses so-called Minifix connectors and wooden dowels for Brimnes furniture. Minifix connectors in particular tend to loosen over time with movement.
This is an important point – to elaborate a bit, the material used in Brimnes furniture is mainly particleboard with melamine coating, which means you should be careful when tightening screws because overtightening can damage the material and strip the threads.
I therefore recommend the following approach:
- First, check the furniture for any loose areas: this means gently pressing on the edges and slightly wiggling the parts.
- Check the connections with Minifix or cam lock fittings for finger-tightness.
- Then gently tighten with an appropriate screwdriver or Allen key. This can be done selectively and not all screws at once.
- Especially with beds, retightening after a few months is important, as the constant load changes from lying down and getting up can cause slight loosening.
You should also regularly check the condition of the holes and dowels, as repairs may be needed if the material becomes worn or damaged.
I’m interested: how often have your furniture pieces been used, how old are they exactly, and have you noticed any signs of material fatigue? This information could help us provide a more targeted recommendation.
U
ulyssespu
10 Feb 2023 09:21
Dilen schrieb:
I’m curious: How often have your furniture pieces been used, how old are they exactly, and have there been any signs of material fatigue?
Thank you for the detailed response! The furniture is about 2 years old and is used daily. The bed, of course, especially, while the sideboard is used less frequently. Material-wise, there are no cracks or chips, but some of the sideboard doors are a bit stiff in places, and after a few months the bed actually feels slightly loose—not broken or anything, just a bit “wobbly.”
I suspect I should systematically tighten things up now. Would you recommend using a standard Phillips screwdriver for tightening, or should I use any special tools? Also, I wonder if it would be a good idea to service any moving parts, such as the hinges on the doors, while I’m at it.
Jensson
11 Feb 2023 10:54
ulyssespu schrieb:
Would you recommend tightening with a standard Phillips screwdriver, or should special tools be used?
Good question! For Brimnes furniture, I recommend:
- For Minifix connectors and cam locks, usually a flathead or Allen key (IKEA typically includes a small Allen key)
- For wood screws, often a Phillips screwdriver with a sturdy handle
Pro tip: Avoid using electric screwdrivers for tightening, as it’s easy to overtighten and damage the material.
ulyssespu schrieb:
whether it’s also a good idea to do something with the moving parts, such as the hinges on the doors.
Yes, definitely. A little lubricant (e.g., silicone or machine oil) on the hinges often helps reduce stiffness. Make sure to use the oil sparingly and immediately wipe off any excess to avoid stains on the wood or finish.
In summary, I would recommend:
- Carefully retighten screws and connectors (firm by hand, but not too tight)
- Maintain door hinges with appropriate oil
- Perform a small maintenance check every six months
This way, your Brimnes will remain stable and functional over the long term!
