ᐅ What is the maximum weight a BILLY shelf can support?
Created on: 25 Oct 2024 08:17
Niaman
Niaman
25 Oct 2024 08:17
I am planning to use a Billy shelf unit from IKEA and would like to know the load capacity of the individual shelves. Specifically, I am interested in how much weight a single shelf can hold without bending or breaking.
I understand that the load capacity also depends on the intended use and how the shelves are fixed in place, so it would be great if you could share examples or experiences – especially regarding shelves that are suitable not only for books but also for heavier items like boxes or equipment.
Thanks in advance!
nubar
25 Oct 2024 08:43
Basically, IKEA rates the BILLY shelf to support up to 30 kg (66 lbs) per shelf, provided the shelves are properly installed and the back panel is in place.
From my experience, if the weight is evenly distributed across the entire length of the shelf, it can handle the load better. Placing heavy objects in a concentrated spot may cause the shelf to bend more quickly.
I recommend not exceeding 25-30 kg (55-66 lbs) per shelf to be on the safe side and to avoid compromising the shelf’s durability.
gasidney
25 Oct 2024 09:12
30 kg (66 lbs) per shelf usually fits without any problems. If you plan to store something heavier, it’s better to use additional supports or choose a different shelf.
Nabla64
25 Oct 2024 10:26
Regarding the load capacity of a BILLY shelf, I would like to provide a more detailed explanation:
1. Material and construction: The shelves are made of particleboard with a melamine coating. The thickness is about 1.8 cm (0.7 inches), which is suitable for light to moderate loads.
2. Maximum load according to the manufacturer: IKEA specifies approximately 30 kg (66 lbs) per shelf. This value is based on evenly distributed loads.
3. Deflection to consider: If shelves are loaded on one side or if the loads are unevenly distributed, deflection can occur more quickly. It is important to take this into account to maintain stability.
4. Reinforcements and tips: Secure the shelving unit to the wall and place heavier items on the lower shelves. If higher load capacity is required, additional metal rods or wooden boards can be added for support.
Summary: 30 kg (66 lbs) is a guideline, but it is safer to use a lower load if the weight is not evenly distributed.
PeoDaniel
25 Oct 2024 12:01
I would like to add:
nubar schrieb:
If the load is evenly distributed along the entire length of the shelf, it can support the weight better.
This is very important because a point load, such as a heavy box, puts significantly more stress on the material at that spot.
Additionally:
- Make sure the back panel is installed. It stabilizes the entire shelving unit.
- For heavier loads, adding extra shelf supports can improve weight capacity.
I have also often seen people reinforce shelves with thin metal plates or wooden slats underneath to increase load-bearing capacity. This is advisable if you plan to store heavier items frequently.
RENMA
26 Oct 2024 07:34
Objectively, the BILLY shelves have a standard load capacity of approximately 30 kg (66 lbs) when the weight is evenly distributed.
Datasheet information (particleboard density about 650 kg/m3, board thickness 18 mm (0.7 inches)) and tests confirm that this load limit is appropriate.
Loads above 30 kg (66 lbs) increasingly cause sagging of more than 4-5 mm (0.16-0.2 inches), which reaches a visually and functionally critical point.
Recommendation: If higher loads are required, either reinforce the shelf with support strips or use a sturdy heavy-duty shelving unit.
Precision and safety when handling shelves for heavy loads are essential.
