ᐅ What is the best way to clean Ikea Hemnes furniture after renovations?
Created on: 13 Jul 2021 08:17
malapau
malapau
13 Jul 2021 08:17
Hello everyone, I recently renovated our apartment and during the process, the IKEA Hemnes furniture set, especially the white dresser and wardrobe, was exposed to heavier dust and construction dirt. My question is: What is the best way to clean IKEA Hemnes after renovations without damaging the surface or finish? Are there specific cleaning products or methods that are particularly suitable for gently and effectively removing fine construction dust, paint residues, or dust? It would be great if you could share your experiences with tips on the procedure, suitable materials, or any warnings, so I don’t make any mistakes.
reni45
13 Jul 2021 08:43
The best approach is to use a soft, slightly damp cloth. Do not use harsh cleaning agents; mild soap is preferable. Do not soak construction dirt; gently wipe it away instead.
Jeanbar
13 Jul 2021 09:05
Hello malapau, I completely understand your caution. When cleaning IKEA Hemnes furniture after renovations, I recommend first gently removing coarse dust and dry construction debris using a vacuum cleaner or a soft brush attachment. Then, use a soft cloth with lukewarm water and a small amount of mild dish soap. It’s important not to soak the furniture to avoid causing the wood to swell. For paint splatters, you should act as quickly as possible using a gentle solvent, such as a little alcohol on a cloth, to avoid damaging the surface. Please test this first on an inconspicuous area.
Tobias
13 Jul 2021 12:16
For removing stubborn dust or paint residues, I use microfiber or cotton cloths. Never use abrasive cleaners or sponges with rough surfaces. Simply use a mild soap solution, then wipe dry.
REOHEINRIC
14 Jul 2021 07:38
Some important points regarding the cleaning of IKEA Hemnes furniture after renovation work:
- Avoid aggressive or solvent-based cleaners, as these can damage the paint finish.
- Clean in several stages: first remove dust and heavy dirt, then wipe with a damp cloth.
- For paint spots, gently remove them using isopropyl alcohol on a soft cloth.
- Always follow by wiping with clean water and allow to dry thoroughly.
- Avoid prolonged moisture or heavy rubbing to prevent damaging the surface.
KAUDRA62
14 Jul 2021 08:21
REOHEINRIC schrieb:
Some important points about cleaning IKEA Hemnes furniture after renovation work:
Exactly! No need to panic— with a little patience, you can get the Hemnes furniture sparkling clean again. I always say: a gentle touch with the cleaning cloth instead of rough scrubbing. Fine dust comes off easily with a microfiber cloth, and it’s better to carefully dissolve paint residues. 😉
