ᐅ What is the safest way to secure Ikea Pax wardrobes to drywall and plasterboard walls?
Created on: 10 Apr 2019 10:23
plokau5
plokau5
10 Apr 2019 10:23
Hello everyone, I am currently planning to mount an IKEA Pax wardrobe on a drywall or plasterboard wall. My question is: what is the safest way to attach the Pax to such walls, which usually have a framework of metal studs or timber and are not solid walls?
I am aware that standard anchors are not sufficient, as the weight of the wardrobe and its contents can be considerable. I would like to know which special anchors or fastening methods you would recommend to ensure the wardrobe is securely fixed without damaging the wall or the fittings.
Additionally, I am interested in how to properly distribute the load on the wall, especially whether additional reinforcement of the plasterboard is advisable or if the wardrobe must always be fixed directly to the studs or metal profiles of the framework.
I look forward to your experiences and tips, particularly on what has worked successfully for you.
Samir
10 Apr 2019 11:05
plokau5 schrieb:
How do you securely attach the Pax to walls that usually have a substructure of metal profiles or wood and are not solid walls?
To securely fasten an IKEA Pax to drywall or plasterboard walls, the key principle is load transfer: the supporting elements of the wall (wood or metal studs) must be engaged.
For fastening, I strongly recommend using expansion anchors or hollow wall anchors specifically designed for drywall. Even better are toggle anchors or bolt anchors that open up behind the plasterboard, providing a large surface area for load distribution.
Important: The screws must be driven directly into the substructure (metal or wood studs), not just into the plasterboard, as the board alone cannot support the weight long-term.
Load distribution can be improved by installing a horizontal support batten behind the wall (for example, a reinforced wooden strip) onto which the wall brackets are screwed. This requires partially opening the plasterboard.
In summary:
- Always transfer the load to the substructure
- Use toggle anchors or bolt anchors
- Reinforce with a horizontal batten behind the wall if necessary
This method is also often recommended by the manufacturer.
WARREN
10 Apr 2019 11:46
Always screw the Pax unit directly into the metal or wooden studs; otherwise, nothing will hold.
Use toggle bolts for the drywall panels, as they provide a much stronger hold than simple anchors.
If possible, add a horizontal batten behind the drywall for better load distribution.
kulau
11 Apr 2019 09:19
plokau5 schrieb:
I am aware that simple wall plugs are not sufficient, since the weight of the cabinet and its contents is quite substantial.
Exactly, that is the crucial point. To securely mount an IKEA Pax wardrobe on drywall or plasterboard walls, you need to have a clear understanding of the structural conditions. Drywall panels alone can only support limited loads, especially point loads from cabinet brackets, which can be problematic.
1. Check the framework: First, you need to determine the exact location of the metal studs or wooden framing behind the plasterboard. A professional stud finder or metal detector works well for this.
2. Fastening directly to the studs: The safest option is to screw the brackets directly into the metal studs or wooden frame. Use narrow, preferably self-tapping wood screws (such as particle board screws) or special screws designed for metal studs.
3. Toggle bolts or hollow wall anchors are useful if fastening directly to the studs is not possible. These anchors expand behind the plasterboard and distribute the load over a larger area – ideal for medium loads.
4. Load distribution: If you cannot screw directly into the framework, it may be sensible to install reinforcement behind the drywall. For example, a sturdy wooden batten installed horizontally across the mounting points and fixed to the studs beforehand. This requires opening the drywall.
5. Additional tips:
- Make sure the wall brackets of the cabinet are mounted exactly level.
- Always use multiple fasteners (at least 2-3 per bracket) to spread the load.
- Check the load capacity of the anchors according to the manufacturer’s specifications before installation.
If your drywall is older or damaged, it may be worth repairing the substrate first, as crumbly plasterboard reduces load-bearing capacity.
What I would also like to know: How exactly are your walls constructed? Are they built with metal or wooden studs? And what thickness are the plasterboard panels? This greatly influences your choice of anchors.
Samir
12 Apr 2019 14:52
kulau schrieb:
If your drywall is older or damaged, it would be advisable to repair the substrate first, as fragile gypsum boards reduce the load-bearing capacity.
This is an important point and should not be underestimated. Damaged drywall panels provide little stability to the wall and can lead to cracks or even breakthroughs at the points of load.
kulau schrieb:
How exactly are your walls constructed? Are they framed with metal or wood studs? And what is the thickness of the drywall panels?
These are essential questions to be able to give precise mounting advice.
I would also recommend always carrying out the installation of heavy, wide wardrobe units in pairs and regularly checking the fastenings after installation to ensure they remain secure and do not loosen over time.
In this context: Which model is your wardrobe and how much does it weigh? The mounting requirements vary depending on the size of the wardrobe.
