ᐅ How can Ikea PAX doors be securely installed?
Created on: 9 Aug 2020 07:53
haukla
haukla
9 Aug 2020 07:53
I am currently facing the challenge of how to securely and permanently attach the doors of the Ikea PAX wardrobes. The question is not only about mounting the hinges to the carcasses but also about aligning the doors and achieving a stable fixation that remains durable over time. Many people report issues with the doors no longer closing properly or warping after a while.
Therefore, I would like to ask you: What installation steps, materials, and possibly tricks do you know to really mount the PAX doors securely and in a way that can withstand stress? Are the original fittings sufficient, or are additional reinforcements necessary? Are there any problems with fastening especially heavy doors or glass sliding doors?
I am very much looking forward to your well-founded tips and practical experiences!
elliot
9 Aug 2020 09:17
For the secure installation of Ikea PAX doors, please consider the following:
- The hinges must be fully recessed into the cabinet carcass and fastened with all the specified screws to ensure stability.
- For heavy doors, such as glass or mirror doors, use the original hinges with additional reinforcement offered by Ikea.
- After installation, precisely adjust the hinges using the adjustment screws in three directions to ensure optimal alignment and smooth, mark-free closing.
- For large doors, it is recommended to install extra mid supports or soft-close door dampers to reduce stress points.
- Check the cabinet carcasses for any warping before installation to prevent later door deformation.
Following these points ensures a durable and reliable installation in the long term.
Tobias
9 Aug 2020 10:24
- Always tighten screws firmly.
- Always use hinges fully.
- Adjust doors after installation.
- Always be cautious with glass, use reinforcement if necessary.
floga
9 Aug 2020 12:56
I completely understand how frustrating it can be when the doors of a PAX wardrobe don’t fit properly and you have to keep readjusting them. I experienced the same issue until I took the time to pay close attention to the alignment and the quality of the screws. Being patient and carefully completing each step makes a huge difference.
Sometimes I also wondered if I was being too rough when drilling or screwing in – this can be especially tricky with glass or mirrored doors. It might help to start with a small test assembly before fixing everything permanently. So, keep your spirits up; if you approach it systematically, you might find that these problems don’t even occur for you.
Kabau
9 Aug 2020 13:02
For Ikea PAX doors, the most important things are:
- Fully install the hinges
- Properly align the doors
- Reinforce the doors if they are heavy
Otherwise, they won’t function properly in the long term.
sonplo
10 Aug 2020 08:43
I would like to add that, besides the correct installation of the hinges, the wall surface or the cabinet structure itself is also important. Especially when installing in older buildings, the wall can be slightly uneven, which affects the fitting of the doors.
I also recommend tightening the screws with the appropriate torque to avoid material overload. A slight gap around the door is normal, but even spacing on all sides is an indicator of proper installation. To prevent shifting, small plastic washers or felt pads can be placed under the hinge mounts.
If glass sliding doors are installed, it is essential to pay attention to the running tracks and their fastenings. Original mounting kits usually provide the best stability.
