I own several IKEA Hemnes furniture pieces, particularly dressers and nightstands, which I would like to keep in good condition for many years. Since Hemnes is made of lacquered pine wood and is relatively sensitive to scratches, moisture, and sunlight, I’m wondering which methods and care steps are truly effective in significantly extending the durability of this furniture.
I’m interested in practical tips for surface care, proper handling during cleaning and everyday use, as well as any preventive measures against warping, cracks, or color changes. Experiences with possible impregnations, sealants, or repair kits would also be helpful.
Has anyone had long-term experience with Hemnes and can specifically share which care routines have proven successful or less effective?
Thanks in advance for all your input and advice!
Alberto519 Sep 2022 11:47Hey Far67,
I can completely understand how important the durability of your Hemnes furniture is – it often has sentimental value and adds to the comfort of your home.
From my experience, it’s especially helpful to clean the furniture regularly but gently – I usually use a damp microfiber cloth and avoid harsh cleaners that could damage the finish. Another tip that has worked for me is not placing the furniture directly by the window, since UV rays can fade the wood and make the finish brittle.
I have also tried natural wood care products, which feel more sustainable to me than synthetic waxes.
What I’m not entirely sure about is repair kits for small scratches or dents on Hemnes furniture. Does anyone have good advice on that?
I’m also open to other suggestions on how to protect the furniture from moisture – especially in bedrooms or living areas where drinks might get placed on the surfaces, which can be tricky.
I hope my experience helps you a bit already. Feel free to keep us updated with your own findings!
Far67 schrieb:
Since Hemnes is made of lacquered pine wood and is relatively sensitive to scratches, moisture, and sunlight, I wonder which methods and care steps are truly effective to noticeably extend the durability of this furniture.In general, Hemnes is fairly sturdy, but pine wood has certain limitations in longevity due to its softer structure and the thin lacquered surface. If you want to extend its durability, you can consider the following points:
- Surface sealing: Since the furniture is already lacquered, I do not recommend applying additional thick layers of lacquer, as this can cause uneven surfaces and cracks. It is better to use thin maintenance oils that are specially designed for lacquered wood; these penetrate the lacquer and provide extra protection.
- Moisture: Hemnes is sensitive to standing moisture. Avoid placing wet glasses directly on the surface; use felt pads or silicone coasters instead. Moisture can cause long-term warping.
- Cleaning: Do not use aggressive cleaners! Mild dish soap with water is sufficient. Avoid abrasive cleaners and rough sponges.
- UV protection: If you have strong sunlight, curtains or UV-protection films on the windows can help. Otherwise, the wood may fade.
- Assembly & use: Occasionally tighten screws and fittings to maintain stability—this prevents wobbling and reduces the risk of damage.
Regarding repairs: There are special wax or lacquer sticks that can be used to touch up small scratches. The color must match well; otherwise, it will be noticeable. For larger damages, professional refinishing might be necessary.
In summary: The best durability is achieved through careful use, regular maintenance, and avoiding extreme environmental conditions such as high humidity or intense sunlight. I would like to know more about your living environment to provide more targeted advice—for example, how exposed your furniture is and the room’s climate conditions.
I hope this gives you a good direction!
glamo schrieb:
Basically, Hemnes is sturdy, but the pine wood has some limitations in durability due to its softer structure and the thin, varnished surface.I would like to point out that the building material itself and the type of surface treatment are the key factors. Pine is a relatively soft wood, which clearly makes it more susceptible to mechanical damage – that can’t be denied.
However, I often find the whole discussion about care and durability overly idealistic. In many cases, the veneer or the coating used by IKEA only provides some initial protection, which tends to wear off fairly quickly in an average household.
So my question to the group is: Does it really make sense to bother with impregnations or oils when the base material is pine, which wears out faster than hardwoods anyway? In the end, isn’t it cheaper to simply replace the item when worn rather than investing a lot of effort into maintenance?
Also, how durable are these additional care products? There are reports that oils can penetrate underneath the varnish layer, ultimately causing more harm than good.
Therefore, it seems more practical to choose furniture specifically for certain uses and to see their durability pragmatically. Sustainability aside, especially in the furniture sector, the realistic service life should not be underestimated.
