ᐅ How should Ikea Brimnes wood surfaces be maintained?
Created on: 1 Nov 2022 08:23
Lojasper
Lojasper
1 Nov 2022 08:23
I recently bought a bedroom set from Ikea with Brimnes wood surfaces. Since I place great importance on proper care and maintaining the value of my furniture, I have a question: How exactly should Ikea Brimnes wood surfaces be cared for?
I have read that these surfaces are melamine-coated, which makes them more resistant to scratches and moisture, but I would like to know how to clean and maintain this material correctly without damaging it or dulling the finish.
Are there any specific cleaning products to avoid? How should stubborn stains be treated? Is it okay to polish or oil the surfaces?
I look forward to helpful and practical tips from you, perhaps also from those with experience with this furniture.
Thank you in advance!
O
olivernu
1 Nov 2022 09:57
As a general rule, when cleaning Brimnes furniture or other melamine-coated surfaces, avoid using aggressive or abrasive cleaning agents, as these can damage the surface.
I recommend using a soft microfiber cloth, lightly dampened with lukewarm water. This is usually sufficient for normal dirt and grime.
For stains that are harder to remove, mild all-purpose cleaners can be an option. However, always test these first on an inconspicuous area.
Polishing or oiling is not necessary for Brimnes furniture, since the surface is sealed and not made of natural wood.
It is important not to leave standing moisture on the surface to prevent water spots or swelling.
GU-LAU60
1 Nov 2022 10:22
In my experience, a damp cloth and occasionally some mild dish soap are sufficient. Scratches are best removed with special furniture touch-up markers. Polishing has little effect on melamine-coated surfaces.
kasan
1 Nov 2022 12:15
olivernu schrieb:
Polishing or oiling is not necessary for Brimnes because the surface is not made of natural wood but is sealed.
I consider this statement important but would like to add a critical question: Are there truly no benefits to applying some kind of protective or maintenance layer on a supposedly sealed surface?
Even melamine can experience slight wear of the protective layer, especially in areas with heavy use.
Does anyone have solid experience on whether, for example, a special furniture wax can offer a real improvement or if it might actually be harmful?
Matthewt48
1 Nov 2022 14:46
kasan schrieb:
Does anyone have solid experience on whether, for example, a special furniture wax can really improve something or if it might actually be harmful?
From my many years of experience with melamine-coated furniture, I can say that waxes or oils usually provide no benefit and, in the worst case, leave residues that make the surface look dull or even cause stains.
Melamine surfaces are designed to be maintenance-free without additional care products. If needed, it is better to use specific cleaners made for plastic or laminate surfaces, which are grease-dissolving but not too aggressive.
Of course, you should always ensure that no liquid remains sitting for extended periods to avoid swelling damage to load-bearing wood-based materials.
edisondan
2 Nov 2022 08:07
To summarize and answer the question precisely:
- The Brimnes wood surfaces are melamine-coated, making them quite durable and easy to maintain.
- Cleaning is best done with a damp, not too wet cloth and mild cleaning agents.
- Avoid abrasive or aggressive cleaners to prevent scratches or damage.
- Polishes or oils are not necessary and may leave unwanted residues.
- Stains should be carefully removed with mild all-purpose cleaners, which should be tested beforehand.
- Moisture should not be left on the surface for extended periods.
These recommendations conform to the manufacturer’s instructions and have proven practical in use.
