ᐅ How can I reinforce IKEA Brimnes furniture to support heavy loads?
Created on: 9 May 2024 08:23
benett51Hello everyone, I have several IKEA Brimnes furniture pieces that I would like to reinforce for heavier loads. Specifically, these are cabinets and dressers from the Brimnes series, where I want to significantly increase the load capacity because I need to store heavier items than the manufacturer recommends.
My question is: What modifications or additional reinforcements are technically feasible and practical to safely and permanently increase the load-bearing capacity of the IKEA Brimnes furniture without affecting the appearance or completely voiding the warranty?
I would appreciate tips, for example, on strengthening the wooden panels, installing additional support braces, using specific materials, or structural reinforcements. A brief note on assembly and any necessary tools would also be very helpful. Thanks in advance!
To reinforce IKEA Brimnes furniture for heavy loads, I recommend the following measures:
- Strengthen the base panels with additional plywood sheets, at least 12 mm (0.5 inches) thick, to prevent sagging.
- Install metal brackets in the inner corners to increase stability.
- Reinforce the back panels with securely screwed wooden boards or OSB panels to prevent twisting.
- Replace the back panel nails with screws for better hold.
- Add extra central supports for large shelf surfaces.
Tools: cordless drill, drill, clamps, wood glue.
This combination significantly increases load capacity while remaining largely visually unobtrusive.
Hello benett51, I am happy to add to andre3’s suggestions with a brief guide:
1. Assessment: First, identify which components carry the load (shelves, side panels, cross braces).
2. Reinforcing the shelves:
- Use plywood panels (12 to 15 mm (0.5 to 0.6 inches)) as support on top of the existing shelves, securing them with screws and wood glue.
- Alternatively, install metal support profiles underneath the shelves for stabilization.
3. Side panels and back panel:
- Reinforce back panels with OSB boards, fastening them with screws instead of nails.
- Fit metal brackets and corner braces on interior edges to increase rigidity of the furniture.
4. Additional supports:
- For particularly heavy loads, metal or wooden supports can be placed inside under the shelves, such as adjustable furniture legs.
5. Installation notes:
- Always pre-drill to prevent splitting.
- After reinforcing, check stability and repeat reinforcement if any movement remains.
This way, you increase load capacity without compromising appearance and achieve a solid construction.
andre3 schrieb:
Reinforcement of the floor slabs with additional plywood sheets, at least 12 mm (½ inch) thick, to prevent sagging. This is the most important point. Thicker sheets distribute the load more effectively.
Additionally, installing metal brackets in the corners is worthwhile, as it significantly improves stability.
benett51 schrieb:
Which modifications or additional reinforcements are technically sensible and practical to safely and permanently increase the load-bearing capacity of the IKEA Brimnes furniture?In addition to the previous suggestion, it should be noted that Brimnes furniture is mostly made of particleboard with a decorative foil finish. This limits the fastening options, as the material can easily chip or break out.
Therefore, using larger diameter screws along with pilot holes is essential. Galvanized steel metal brackets and additional cross supports made of solid wood provide the best combination of stability and durability.
Optional: For large shelves, add a vertical support in the middle area.
This increases the load capacity without significantly affecting the appearance or altering the piece of furniture too much.
