ᐅ How can I properly repair damaged edges on Ikea PLATSA units?
Created on: 18 Jul 2016 08:17
techenHello everyone, I recently noticed some edge damage on my Ikea Platsa system, which varies depending on use: sometimes the edges are only slightly bumped, but other times there are small chips in the veneer or even slightly torn areas of the plastic edging. My question is how to properly repair these damages so that the result looks as inconspicuous and durable as possible. I am familiar with basic materials like filler, wood glue, and sandpaper, but I’m unsure whether and how to apply them in the case of the Ikea Platsa edges, especially because of the special plastic or melamine coating. Does anyone have experience with effective methods, suitable products, or tips for preparation and finishing? It would be great if you could also recommend tools or techniques to make the repair look professional and prevent it from getting damaged again quickly.
Repairing Ikea PLATSA edges requires some care, as the surface is often made of melamine-coated particleboard, which cannot be treated like solid wood. I recommend the following step-by-step method:
- First, lightly sand the area around the damage to remove loose parts and roughen the surface for filling.
- Then carefully fill the damaged spot with a special repair filler based on polyester or wood. Make sure the filler adheres well and is not applied too thickly.
- After drying, gently smooth the area with very fine sandpaper (at least grit 320 or finer).
- For color matching, either color-matching furniture markers or water-based acrylic paints applied with a very fine brush or a sponge are suitable.
It is also important to apply a thin protective layer afterward, for example with a matte clear coat, to protect the spot from further wear. What level of damage do you have exactly? Small scratches, chips, or larger defects?
FAZAR schrieb:
What level of damage do you have exactly? Minor scratches, chips, or more significant damage? Thank you for the detailed answer. The damage is mixed: in one area, there are only small scratches or dull spots, but on another edge, there are some small chips in the plastic veneer, about 1–2cm (about 1 inch) long, and in some spots, slight swelling. How would you approach this kind of damage, especially the chips? Does a solvent-based furniture marker harm the surface, or are water-based paint options better? And how can you achieve the most seamless repair possible?
Interesting question, but I am a bit surprised by how much work is being put into a piece of furniture that is actually intended for affordable, rather utilitarian use. One should consider whether such repairs require more effort and materials than a replacement part or even a new purchase, especially if the edge banding is already older and there is a risk of further damage.
That said, if sustainability or aesthetics are important, I would be interested to know if there are truly suitable repair products compatible with melamine or plastic edge banding, since many wood-based fillers can crack or chip after repeated stress. A scientific analysis or product testing would be helpful here; does anyone in the forum have experience with this?
I find this discussion really interesting – but at the same time, it’s a shame when the good old PLATSA system is affected by minor damage. 😕 From my personal experience, I simply bought some self-adhesive edge protectors that you can stick on as a temporary fix when the edges get too worn. Of course, this isn’t the most visually appealing solution for everyone, but it’s practical as a short-term measure until a proper repair can be done.
Regarding proper repairs: I would experiment a bit before investing in expensive repair kits. This also includes color-matched furniture markers – which often come in sets – and can work wonders. For larger dents, use filler. I believe with patience and a good sense of humor, it works out quite well – after all, we all want the furniture to last a long time! 😄
