ᐅ How can I permanently repair damaged back panels or boards on IKEA BESTA units?
Created on: 17 Oct 2017 14:03
renni34
Hello everyone, I have noticed that the back panel and some of the boards of my IKEA Besta shelf are damaged in several places – some are dented, others swollen due to moisture. I am especially interested in how to repair these damages in a durable and stable way without having to take the entire shelf apart or buy completely new panels. Are there any proven techniques, materials, or specific methods that have been shown to be long-lasting? Perhaps someone has experience with DIY repairs on the thin particleboard panels used in BESTA? I look forward to your advice!
lenren
17 Oct 2017 20:04
renni34 schrieb:
Some nail points are loose, which probably further reduces stability.
It’s better to remove the nails and use small screws instead. This will make the back panel hold better in the long term and be more stable against lateral forces.
Rosstar
18 Oct 2017 09:13
An addition to the previous recommendations: If you replace the back panel, make sure to choose a board that is as warp-resistant as possible – MDF is better suited than inexpensive chipboard because it absorbs less moisture. I also recommend not only gluing the back panel from the inside but additionally securing it with thin screws and metal strips to stabilize the shelving unit. If necessary, reinforcing strips can be glued to the edges of the back panel, which will hardly be noticeable from the inside. Small gaps can be filled with wood filler, but avoid filling large holes, as this will cause the screws to lose their grip.
NEREO
18 Oct 2017 11:22
Wood glue combined with screws and reinforcements usually provides very strong support. If desired, you can protect the surfaces with felt tape against scratches on the floor, in case you need to access the area for repairs.
NUPIN
19 Oct 2017 08:45
I think projects like these are fun and you learn a lot! 🙂 Just work patiently, cut the panels accurately, and always make sure nothing is loose. If you use a thicker back panel, it will keep the shelf nice and stable! Don’t get discouraged, it will turn out great!
fidasi
19 Oct 2017 12:31
lenren schrieb:
Then it’s better to remove the nails and use small screws.
Exactly – nails have much less grip in chipboard than screws. Even better is to prepare dowels or small wooden plugs in the cabinet body, as they distribute the load better and prevent pull-out. When I have time, I make a separate assembly aid that allows such repairs to be done very precisely.
Regarding the question of moisture: If the back panel in the shelving unit is often exposed to humidity (e.g., in certain spots due to openings), it is worthwhile to treat the plywood lightly with varnish or a thin layer of wood preservative before installation. This helps prevent further swelling. How large are the damaged areas overall?
