ᐅ How can I optimize the installation of Ikea Metod kitchen units in small spaces?
Created on: 6 Dec 2018 08:42
sonpau42
sonpau42
6 Dec 2018 08:42
Hello everyone, I am currently planning and installing an Ikea Metod kitchen unit for a very small space (approximately 2.5m x 2.0m [8 ft 2 in x 6 ft 7 in]). The challenge, of course, is to achieve both functionality and as efficient use of space as possible.
I am especially interested in any experiences and tips you have for optimizing the installation – specifically, how to best arrange, secure, and align the kitchen units in a limited area without making the installation unnecessarily complicated or causing stability or usability issues later on.
Are there any special tricks for alignment in small rooms, clever installation techniques, or alternative fastening methods you would recommend? I look forward to your opinions and insights!
sifa65
6 Dec 2018 13:25
sonpau42 schrieb:
The challenge, of course, is to achieve both functionality and the most efficient use of space possible.
This is the key point with small rooms. My tip for installation: use a horizontal alignment of the cabinets with filler panels to compensate for minor wall irregularities. Ikea Metod is very modular, so it helps to prepare all the upper cabinets first and temporarily fix them to the wall before installing the base cabinets. This prevents the kitchen from warping later on.
- Pay close attention to leveling and adjust the feet if the floors are uneven.
- Use strong wall fixings, especially with lightweight partition walls.
- To optimize space, include corner cabinets with carousel or Le Mans pull-out fittings, which work very well in tight spaces.
In general, calmness and patience during installation are essential to avoid mistakes that are difficult to fix later.
JOHNATHAN
7 Dec 2018 10:07
sifa65 schrieb:
Make sure to use a very precise spirit level and, if necessary, adjust the feet on floors with a slope.
Exactly, and if the floor isn’t cooperating, it can be really frustrating!
What I would additionally recommend: if you are assembling Metod cabinets row by row, ventilation strips under the base cabinets can help prevent dampness or mustiness—especially in small rooms where air circulation is often limited.
Also, I find that decoupling with extra seals in certain areas is useful to make the kitchen a bit more resistant to stress. Although this makes the assembly process slightly more complex, it’s worth the effort.
And hey, when space is tight: small helpers like magnetic strips for screws and tools are invaluable to keep everything from getting lost!
buEspen
7 Dec 2018 14:23
I would summarize this very pragmatically:
- Measure and check walls accurately
- Plan corners carefully (Le Mans pull-outs are great for small kitchens)
- Do a full dry run on the floor before installation
- Adjust the legs precisely
- Secure wall mounts multiple times
This will save you trouble later.
Teonon
8 Dec 2018 07:16
sonpau42 schrieb:
Are there any special tips for aligning in small rooms, clever installation steps, or alternative fastening methods that you would recommend?
Absolutely! Especially in small rooms, I really like the following approach:
- Start by identifying the visually central position of the kitchen to create a harmonious effect, and align all modules from there.
- Use angle brackets for additional stability that don’t add much bulk.
- I also recommend using special mounting strips on the wall, which you install completely beforehand, making it easy to snap the modules into place.
- And don’t forget: thorough planning saves a lot of time and frustration during installation!
With Metod, all of this is perfectly feasible. Good luck and above all, enjoy your project!
