AndiArbeit-19 Aug 2012 19:33Hello everyone,
I am planning to pour the screed in the bathroom soon. I’m not an expert in this area. Do I need to prime the screed first (for example, with Gisogrund), or should I sand it first and then prime it – or apply a resin? What is the best way to proceed?
MODERATOR11 Aug 2012 23:11Tiling work in the bathroom requires a skilled professional with expertise. There is a risk that improperly installed tiles and incorrect waterproofing can cause water damage, which ultimately ends up costing more than hiring an expert from the start.
Good, if you haven’t done this yet, it is advisable to hire a professional company. However, if you want to try it yourself and have the calmness and patience, you can do it on your own.
The subfloor must, of course, be solid and clean. If it is, then apply a primer. Next, carefully check if the floor is level. After that, apply the screed.
Ricardo-13 Jun 2014 23:04In the bathroom, I would always be cautious with attempting that. If it is not done properly and water damage occurs, it can be very costly.
