ᐅ How can I install Billy shelves without using wall anchors or plugs in rental apartments?
Created on: 28 Feb 2022 09:17
taylan60
taylan60
28 Feb 2022 09:17
Hello everyone, I’m moving soon and want to install Billy shelves in my new rental apartment, but unfortunately, I’m not allowed to use wall anchors or drill any holes. I still want my shelf to be stable and not tip over, as I plan to put books and some decorative items on it. Does anyone know how to securely fix Billy shelves without any anchors or drilled holes? I would appreciate tips that also work on rather smooth walls, since there is no textured wallpaper or anything similar. Thank you in advance for your experiences or suggestions!
mopra42
28 Feb 2022 10:02
You can try special clamp brackets or heavy-duty adhesive tapes. Back panels with added weight often provide sufficient stabilization as well. However, for heavy items, I definitely wouldn’t rely solely on adhesive.
O
olivernu
28 Feb 2022 11:45
An important consideration is the shelf unit's inherent stability. Billy shelves can be fairly easily reinforced with additional shelves or back panels, which increases stability. For mounting without wall plugs, I recommend using a tension rod system between the shelf and the ceiling, known as a ceiling tension rod, which works by tension. This leaves no drill holes, as it only presses against the surfaces. Another option would be to reinforce the shelf with sturdy furniture brackets attached directly to the shelf board to prevent wobbling.
Katan
28 Feb 2022 12:38
Sounds like a plan! 🙂 I’ve seen these “no-drill” shelf brackets made exactly for rental apartments. You just clamp them in place or use strong 3M adhesive tape. But be careful, they only hold if the shelf isn’t carrying too much weight. Books? Then it’s better to combine them with ceiling supports or something similar! 😉
puvin
28 Feb 2022 14:21
Oh, that's brilliant! 🙂 I secured my Billy shelves using a combination of anti-slip mats under the shelf and so-called furniture brackets attached to the ceiling – all without any drilling! It holds really well, even when the shelf is loaded heavier. Give it a try; it’s a really simple and quick solution that doesn’t interfere with the look! Good luck, fingers crossed for you!
taylan60
1 Mar 2022 08:53
Thanks in advance for your tips! The idea of ceiling tension rods sounds interesting. I’m just wondering if they might still leave pressure marks on the ceiling? The apartment has just been freshly painted, and I want to avoid any damage, especially anything visible later on. Does anyone have experience with this or specific product recommendations? I also find the tape idea intriguing, but I’m concerned that the weight of books might be too much for it.
