I am planning to disassemble my IKEA Malm bed but want to avoid damaging the wood or breaking any parts. Since I intend to reassemble it later, it is especially important to me that the joints and screws remain intact. Could someone explain in detail how to best take the bed apart, particularly which tools are useful and how to handle areas that might be a bit stuck? Are there any spots where extra caution is needed or common mistakes to avoid? I look forward to practical tips and experiences!
Hello Alexa54,
here is a brief step-by-step guide on how to disassemble your Malm bed without causing any damage:
1. Preparation: Carefully note or mark the position of all screws (e.g., with a sticky note). This will make reassembling much easier later on.
2. Tools: Have an Allen wrench (usually 4mm or 5mm), a screwdriver with the appropriate bit, and if needed, a rubber mallet ready.
3. Disassembly: Work methodically from the outside toward the inside—for example, start with the slatted frame supports before moving on to the main frame.
4. Loosen screws slowly and gently. If they are stuck, as suggested by KINMIN4, warm the screws slightly with a hairdryer. This helps make the wood more flexible.
5. Avoid levering forces: Do not use excessive force to pry or pull parts apart, as this can damage the veneer or the wood.
6. Store the individual parts securely and plan enough space for careful storage.
One more tip: Some users report that applying a bit of silicone spray to the screws during reassembly makes it easier to unscrew them later.
If there are specific spots where you’re stuck, feel free to ask again.
KINMIN4 schrieb:
Always unscrew slowly and straight, avoid tilting.That's true, especially with older furniture you need to be careful not to damage the surface.
fugolo schrieb:
1. Preparation: Carefully note or mark the position of all screws (for example with a sticky note), this makes reassembling much easier later.That’s a very good tip! I have taken apart a piece of furniture before and got annoyed when the screws got mixed up.
What about side panels? They often have dowels installed. How can I best remove those without them giving way or breaking? Does anyone have experience with this?
Alexa54 schrieb:
What about the side panels? Dowels are often used there. What is the best way to remove them without causing them to loosen or break?Dowels are indeed often a weak point when disassembling furniture. My advice:
- First, loosen all screws and hidden fasteners that hold the side panel.
- When separating the side panel, apply gentle pressure and avoid pulling abruptly – dowels are usually quite tight.
- Soft wood joints come apart more easily if they are slightly warmed in advance with a heat gun, as mentioned before.
- If the dowels are very tight, you can carefully pry the joints apart with a small wooden wedge. Be sure to watch the angle of pressure to avoid damaging the wood.
- If there is room, place a thin cloth or cardboard between the lever tool and the furniture to protect the surface.
The goal is to distribute the forces as evenly as possible rather than focusing them on one point.
