Hello everyone, I plan to install Ikea Metod kitchen cabinets on my relatively thin walls in an older building with drywall panels that are only about 10 mm (0.4 inches) thick. The walls offer hardly any solid support for heavy mounts, so I’m wondering about the best way to securely and permanently fix the cabinets without damaging the walls or risking the cabinets falling down later.
I’m really looking for practical solutions and advice regarding anchors, brackets, possibly reinforcing from behind the wall, or alternative mounting systems. It’s especially important to me that the installation is as secure as possible, since the cabinets will be fully loaded and under a lot of weight.
Have any of you had experience mounting Ikea Metod cabinets on thin drywall or similar walls? Which methods have proven reliable? Are there any tricks for reinforcement behind the wall? I’d appreciate any advice!
trana39 schrieb:
The walls offer little direct support for heavy installationsHey, that sounds like a challenge, but don’t worry, there are some great ways to securely install your Metod cabinets on thin walls! 😎
I would recommend using heavy-duty hollow wall anchors or specialized metal anchors instead of regular plugs – these expand behind the drywall and distribute the load. Also, check if it’s possible to install a wooden batten framework behind or on the wall – basically a sturdy frame you can firmly screw into.
Sometimes it also helps to additionally secure the cabinets from above on the ceiling or surrounding walls to better distribute the weight.
Better safe than sorry – spending a bit more time on preparation really pays off so the cabinets don’t come crashing down later. And a little fun during installation is always part of the deal, right? 😉 Good luck with your project!
Hello trana39,
I have read your post and would like to address the topic in more detail, as installing Ikea Metod cabinets on thin walls can indeed pose some disadvantages and risks if not done correctly.
Here is a structured approach that typically works:
- First, check if there is a load-bearing wooden beam or metal stud construction behind the drywall. These can be used as anchoring points.
- If yes, make sure to fasten directly into these studs, as standard drywall anchors without backing do not provide sufficient support.
- If there is no load-bearing substructure, I recommend using hollow wall metal anchors or toggle bolts (butterfly anchors). These expand inside the cavity behind the drywall and offer better hold.
- Another very reliable method is to install a sturdy wooden frame or panel, which you secure with multiple screws across the wall surface (always into load-bearing points). Attach the Metod cabinets to this frame.
- When selecting anchors and screws, pay attention to their maximum load capacity and include a safety margin (at least 20–30% more than the weight of your heaviest cabinet).
Common mistakes are:
- Relying only on simple drywall anchors, which can fail after a short time.
- Overloading cabinets without verifying the anchoring’s load capacity.
Conclusion: With proper preparation and, if necessary, additional reinforcement behind the wall, the project can be completed safely and for the long term.
LAURE-TA schrieb:
If no load-bearing substructure is available, I recommend using hollow wall anchors or so-called toggle bolts (butterfly anchors).Exactly. I have had good experience with toggle bolts on drywall. It’s important to use the right type for the weight and to install them correctly. Otherwise, as mentioned, rely on reinforcements such as a wooden batten behind the wall.
trana39 schrieb:
Does anyone have experience with mounting Ikea Metod cabinets on thin drywall or similar walls?I’m familiar with that issue; old walls with low load-bearing capacity can be really frustrating. I was a bit worried the cabinets might fall down. My advice: don’t overload them, even if there is a wooden batten attached to the wall.
Sometimes it helps to provide additional support on the sides or underneath the cabinets, especially for larger units. That gives me a better feeling of security and more stability.
I know technical solutions are very important, but practical aspects like proper loading also matter. Maybe you can also try to distribute the weight a bit, if possible. I hope you find a solution that gives you peace of mind.
