ᐅ How can IKEA Hemnes be used as a base for an upcycling project?
Created on: 27 Sep 2020 16:12
Puelti
Puelti
27 Sep 2020 16:12
Hello everyone, I would like to know how IKEA Hemnes furniture can be used as a basis for exciting upcycling projects. Specifically, I’m interested in which features of the Hemnes series are particularly suitable for redesign, for example through remodeling, painting, or functional modifications. Which parts are especially sturdy or versatile? Are there any tips on how to best work on or prepare the typical wood surfaces to create durable and attractive new furniture pieces or home accessories? I look forward to ideas and experiences on how you have creatively reused or transformed Hemnes furniture, what challenges you encountered, and which tools or materials worked best for these projects. Thanks in advance for your help!
LuMarcel43
27 Sep 2020 17:43
Puelti schrieb:
Which parts are particularly sturdy or versatile?
I think the dressers from the Hemnes series provide a good foundation due to their simple yet robust construction. However, I would seriously question how “stable” they really are under continuous heavy use, especially if you plan major modifications. Because of the rather thin solid wood panels, you shouldn’t apply too much weight or pressure in specific areas.
Puelti schrieb:
typical wood surfaces best treated or prepared
Here, I strongly recommend sanding the surface thoroughly first—but be careful with the varnish layer since there are often particleboard reinforcements hidden underneath. Incorrect treatment can quickly cause unsightly cracks or chipping. Overall, I find Hemnes to be versatile, but you have to be aware of its limitations, especially if you have the highest demands for durability and stability.
rickey
27 Sep 2020 18:07
I can understand the concerns of @LuMarcel43. I once completely converted a Hemnes dresser into a shoe cabinet. For me, it was important to thoroughly prepare the wooden parts, sanding them extensively and then treating them with a high-quality wood oil. This made the surface significantly more durable, and the visual effect was great.
It’s also important not to stress too much if something isn’t perfect. Upcycling is all about preserving character and adding unique features. For me, it was a wonderful experience because I felt like I was giving the furniture a new purpose.
Ernesto
28 Sep 2020 09:29
To successfully carry out upcycling projects based on IKEA Hemnes furniture, it is important to understand and consider certain technical details. Hemnes primarily uses pine wood, known for its combination of lightness and durability, but also for its particular characteristics when working with the surface.
First, regarding stability: The solid frame construction is excellent for modifications where you want to replace or add furniture elements—such as installing new drawer fronts, additional compartments, or interior fittings. However, it is important to always check the joints, as the glued connections and dowels in Hemnes furniture are not designed for excessive stress.
When it comes to working on the wood surfaces, I recommend thorough preparation:
- Start by removing all old paint layers with fine sandpaper (around grit 180-220).
- Then, apply a wood primer or stabilizer, especially for older pieces.
- For the new finish, you can use acrylic paint for a glossy, wipeable surface or natural oils/waxes to highlight the character of the wood.
Additionally, it makes sense to round off or smooth the wood edges before modifications, since Hemnes furniture often has rather sharp-edged designs, which can affect comfort when used for new functions (for example, as a bench or shelf). Tools such as routers or random orbital sanders are very useful for this.
One more question for the original poster: Is there a specific Hemnes furniture type you are focusing on? Dresser, bed, wardrobe, or sideboard? That would help provide more targeted advice.
Alice
28 Sep 2020 11:45
I renovated Hemnes nightstands: simply stripped the paint, sanded them down, and repainted – done. Sturdy enough for lamps and books. Very suitable for furniture with flat surfaces.
Muso4
28 Sep 2020 12:51
Ernesto schrieb:
It’s also a good idea to round off or smooth the wooden edges before renovations, as Hemnes furniture often has a very angular design
Interesting, but I think that sharp, angular design is exactly what gives Hemnes its charm and creates a contrast to the upcycling ideas. So why not deliberately use this style to integrate modern elements like lighting or metal accents? I believe it’s a mistake to see Hemnes as a sterile base that needs to be softened first. Sometimes the best tension between original and new is created precisely by this contrast.
I would even advocate emphasizing the ‘mass-market’ aspect of IKEA Hemnes and intentionally breaking it in an ironic or provocative way. That makes the piece more unique and really stands out in trendier living spaces.
