ᐅ How can Ikea Brimnes furniture be protected from UV damage?
Created on: 21 Feb 2023 18:07
Clement40
Clement40
21 Feb 2023 18:07
Hello everyone, some time ago I bought several Ikea Brimnes furniture pieces and really like their simple design. However, I have now noticed that the surface darkens significantly or even fades due to sunlight exposure, which is especially a problem near windows with strong sunlight. Therefore, my question to the community: What practical and effective methods are there to protect Ikea Brimnes furniture from UV damage without negatively affecting their appearance or material properties? Are there special varnishes, UV protection films, care products, or other treatments that you would recommend? Tips on positioning or prevention would also be appreciated. Thank you in advance!
TRADI
21 Feb 2023 18:39
Hello Clement40,
first of all, this is a good, specific topic because the Brimnes panels are made of laminated particle boards, which can actually change color and deteriorate when exposed to UV light.
- The most effective way is to keep the furniture away from direct sunlight, for example by using curtains, blinds, or UV-protective windows.
- UV window films are a common option that filter most of the UV light and help protect the furniture.
- Alternatively, you can use special furniture waxes or care products that contain UV protection – these form a thin protective layer on the surface.
- Be cautious with paints or varnishes: since the Brimnes fronts are laminated, paint may alter the appearance and possibly peel off. Clear water-based varnish would be the gentlest solution, but test it first on an inconspicuous spot.
If possible, position the furniture to minimize direct exposure to sunlight. Also, keep the surface clean from dust, as dirt can intensify UV effects.
I hope this helps you!
RENMA
22 Feb 2023 08:14
Brief and factual: Ikea Brimnes furniture has a laminated surface that is sensitive to UV radiation and may fade after prolonged exposure to light.
Recommendations:
- Install window films that block up to 99% of UV radiation.
- Regularly rotate furniture within the room to ensure even light exposure.
- Use care products with UV blockers, such as furniture polishes containing additives for light protection.
- Invasive measures like painting are not recommended, as the laminate could peel off.
These steps significantly extend the appearance’s lifespan.
TRADI
22 Feb 2023 13:57
RENMA schrieb:
Recommendations:
- Install UV protection films on windows that block up to 99% of UV radiation.
- Regularly rotate furniture in the room to ensure even exposure to light.
- Use care products containing UV blockers, such as furniture polishes with added light protection agents.
- Invasive measures like varnishing are not recommended, as the film might peel off.
That sums it up very well. Additionally, I would like to point out that especially with film surfaces, the material itself should not react to water or solvents.
Clean gently and avoid harsh cleaning agents. For extra protection, there are also special furniture UV sprays that temporarily form a protective layer without dulling the shine. However, these should be reapplied regularly.
Also: if space allows, relocate furniture once each season so that sunlight does not consistently hit the same spot—this helps prevent permanent fading.
TAUFA
22 Feb 2023 20:24
Apply UV protective film to windows; this reliably protects furniture. Alternatively, use curtains. Do not place furniture directly against the window.
Lukesan
23 Feb 2023 11:35
Simply rotate furniture regularly and spray a UV blocker on the surface. This helps to minimize color fading.
