ᐅ How can I use Ikea Platsa furniture for an office?
Created on: 18 Jan 2016 08:37
NEJESSIE
NEJESSIE
18 Jan 2016 08:37
I am currently considering how to effectively use Ikea Platsa furniture in an office setting, especially regarding flexible storage and organized workspaces. Since Platsa is primarily marketed as a modular system, I am interested in how the individual element combinations can be adapted to different office requirements.
Are there any experiences regarding the stability and load capacity when using the modules, for example, as shelving units or side tables? And what about cable management or integrating work surfaces? I am looking for a solution that works well for both home offices and small teams.
Which modular arrangement or configuration has proven effective for you, and what should be particularly considered when purchasing and planning, especially concerning functionality and durability?
Noahlu
18 Jan 2016 10:52
Regarding the topic "How can I use Ikea Platsa furniture for the office?" I can share some detailed insights, as I experimented with this last year.
First, about stability: Platsa is primarily designed for residential use, so the materials are lightweight but not of inferior quality. For typical office uses, where mainly documents and light equipment are stored, the system performs well. However, when assembling, it is important to properly secure the modules with the supplied connection screws and brackets; otherwise, the constructions can become unstable. For heavier equipment, I always recommend using smaller support frames or firmly anchoring the units to the wall or floor.
Regarding cable management: Ikea does not provide specific cable conduits for Platsa, but you can create holes in the back panels or attach special clips to neatly organize power and network cables.
When it comes to integrating work surfaces, Platsa can be extended using suitable tabletops or custom-made covers. It is important to consider the curves and support areas to ensure everything remains stable.
For planning, I suggest accurately measuring in advance which modules are actually needed. The system’s flexibility allows versatile combinations — for example, tall cabinets for binders, shallow drawer chests for small items, or open shelves for files.
What does your work environment look like exactly — home office or shared workspace? That could influence the modular setup.
If you like, I can also help you plan individual modules or send examples from my collection.
ritotar
18 Jan 2016 13:09
Noahlu schrieb:
Regarding "How can I use Ikea Platsa furniture for the office?" I can share quite a bit of detail, as I experimented with exactly that last year.
That sounds great, thanks for the detailed tips! :-)
I really think Platsa is a really cool system because it doesn’t feel so rigid. Its modular design makes it perfect for flexible office layouts, and with a bit of creativity, you can make it both cozy and practical at the same time!
Personally, in my home office I combined Platsa with caster wheels under the lower modules, so the cabinets and shelves are mobile and I can rearrange the space depending on whether I need more room for working or additional storage space.
For cable management, I used simple spiral cable ties – nothing fancy, but effective and inexpensive. The doors have magnetic catches to prevent rattling, which is really valuable during video calls.
So if you’re up for a bit of DIY with Platsa and want to stay flexible, I highly recommend it. How about you – do you prefer closed cabinets or open shelving?
flope60
19 Jan 2016 09:15
Here is a structured approach to using Ikea Platsa in an office setting:
- Planning: Start by sketching the available space and consider which functions need to be covered (filing, work surface, technology, storage).
- Use modularity: Combine different Platsa units as needed, for example, placing several wide modules side by side to create a continuous workspace.
- Ensure stability: Connect the modules with the included connectors and, if necessary, secure the units to the wall to prevent tipping hazards.
- Consider ergonomics: Plan work surfaces at an appropriate height (around 72-75 cm (28-30 inches)), possibly using additional tabletops placed on top of the modules.
- Cable management: Install cable channels or clips inside the units to organize power and data cables.
- Doors and drawers: Use these to keep things organized and maintain a tidy appearance.
Common mistakes:
- Not properly connecting the modules, leading to instability.
- Choosing work surface heights that are too low or too high.
In summary, Platsa is well suited for home offices or small offices due to its flexibility; however, for heavy loads, more robust additions are advisable.
A small note: If desired, I can also provide specific measurements and suitable product combinations.
LuMarcel43
20 Jan 2016 11:03
NEJESSIE schrieb:
I am currently considering how to effectively use Ikea Platsa furniture in the office, especially regarding flexible storage and organized workspaces.
I think the idea of using the system modularly is good, but I see a few concerns here:
Platsa, as mentioned before, is designed for residential spaces, which means its durability might not be sufficient for long-term and intensive office use. I would be cautious about using it for drawers that are opened frequently every day or as a surface for heavy office equipment like printers or larger computers.
flope60 schrieb:
Platsa is good for home offices or small offices because of its flexibility; however, for heavy loads, more robust additions are advisable.
I completely agree with this; it’s important to clearly understand the system’s limitations.
Furthermore, there is no mention of the ergonomic aspect: What about using individual Platsa modules as storage combined with a separate height-adjustable desk? The principle of “store separately, work separately” might be better from an organizational point of view.
Does anyone have experience with how well Platsa tops work with standard desks or custom-built work surfaces? Are there practical tips or potential pitfalls during installation, especially if you want to place custom tops on them?
