ᐅ How can I repair damaged edges on Billy bookcases myself?
Created on: 15 Feb 2020 08:23
KEOKRISTO5
KEOKRISTO5
15 Feb 2020 08:23
I have some damaged edges on my Billy shelf unit, which have become quite worn and partially chipped due to frequent use and moving. The edges are laminated or covered with a plastic edge band. My question is: How can I repair these damaged edges on Billy shelves myself without having to dismantle the entire unit? Are there effective methods or materials that a non-professional can easily use to restore the shelves so they are functional and visually appealing again?
It is especially important to me that the solution is durable and as discreet as possible. Any advice on preparing the damaged areas, suitable adhesives, or choosing and applying edge protectors or repair strips would be very helpful.
Thanks in advance for your tips!
mifra
15 Feb 2020 09:12
KEOKRISTO5 schrieb:
How can I repair damaged edges on Billy shelves myself without having to disassemble the entire shelf?
A practical solution is to gently sand the damaged edges, remove any loose laminate residues, and then apply new PVC edge banding. These strips are available as self-adhesive versions at hardware stores and can be cut precisely to the required length.
KEOKRISTO5 schrieb:
Any tips on preparing the damaged areas, suitable adhesives, or selecting and applying edge protectors or repair strips would be very helpful.
If self-adhesive edge banding is not strong enough, I recommend using a contact adhesive such as UHU Kontakt Extrem. Before application, the surface should be clean, dry, and free of grease. For chipped areas, it helps to fill them lightly with wood filler from the hardware store and then sand finely to create a smooth edge.
This combination ensures long-lasting durability and a good visual result.
gasidney
15 Feb 2020 10:07
Carefully peel off the edge banding, remove any adhesive residue, purchase new self-adhesive PVC edge banding, cut it precisely, and apply it. Done.
O
ottilie
16 Feb 2020 14:36
mifra schrieb:
If self-adhesive edges are not stable enough, I recommend a contact adhesive like UHU Kontakt Extrem.
I think that approach is too limited. Why always just fix the surface? In my experience, the Billy isn’t exactly a masterpiece – so why not glue on an improvised wooden strip or MDF strip and sand it down? This would be more durable than the original edge banding.
KEOKRISTO5 schrieb:
The edges are veneered or covered with a plastic edge band.
That edge banding usually doesn’t last long under regular use anyway. You could create a solid base here with wood glue and filler, then repaint it in a matching color. That often looks better than a self-adhesive patch that tears or peels off after a short time.
You might spend a bit more time, but quality pays off.
