ᐅ How can I prevent Malm drawers from sagging or dropping?
Created on: 11 Feb 2020 09:17
klo-san
klo-san
11 Feb 2020 09:17
I own several MALM dressers from IKEA with the typical drawers, and I have noticed that over time the drawers tend to start sticking or no longer close smoothly and flush. This makes daily use more difficult and also affects the lifespan of the furniture. My specific question is: How can I effectively prevent or protect MALM drawers from this issue, commonly known as sticking or misalignment? Are there any maintenance tips, suitable materials, or adjustment or repair methods you would recommend? I am especially interested in long-term protection and stability, not just quick fixes. Thanks in advance!
O
onron
11 Feb 2020 11:43
klo-san schrieb:
My specific question: How can I effectively protect MALM drawers from this problem, the so-called "catching" or "warping," or prevent it?
The issue with MALM drawers often comes down to the relatively simple slide rails, which wear out over time or become misaligned. My recommendation for long-term protection:
1. Regularly clean the slide rails, as dust and small particles can block the mechanism.
2. Use silicone spray (not oil) to keep the sliding components smooth.
3. Check the side screws regularly—these tend to loosen with use.
4. If there are visible deformations in the drawer, adjusting or resetting the guide rails usually helps.
Sometimes it’s also worth replacing the original slide rails with more robust, higher-quality alternatives. This significantly improves durability.
taudi
11 Feb 2020 14:16
I would like to revisit the points made by onron in a more structured way, as this topic is often reduced too much to just repairs, while maintenance and preventive measures play a much bigger role.
First: The bearings of the drawer slides must remain clean and undamaged. Depending on use, it is sufficient to remove dust and lint every 6 months or so with a microfiber cloth. Dust mixes with lubricant and can cause jamming.
Second: The right lubricant is essential. Silicone spray is particularly suitable because it does not become sticky. I advise against oils or greases, as they attract dust.
Third: Regularly tighten the screws on the drawer runners. Despite this, screws can loosen over time due to movement and cause wobbling.
Fourth: Check drawers for damage, especially the small plastic parts and the ends of the slides. If these break, drawer misalignment can occur more quickly.
Brief conclusion: Prevention through regular maintenance, targeted tightening, and lubrication significantly increases longevity compared to just performing repairs.
plo60
12 Feb 2020 08:07
I would like to take a closer look at the root cause, as "getting stuck" is a symptom, not the problem itself.
klo-san schrieb:
…how can I protect MALM drawers from so-called "getting stuck" or "warping," or prevent these issues?
The MALM dresser uses inexpensive zinc die-cast slides and simple plastic rollers. This design is durable but also prone to deformation if the load is uneven or if the slides are damaged by improper installation. Here, factors such as the furniture’s weight and frequency of use must be considered.
It is possible to improve the original slides, but this will not eliminate all mechanical stresses. Therefore, I recommend paying attention to proper loading of the drawers (no overloading, always distribute the load as evenly as possible).
Over time, you might also consider replacing the slides with metal models featuring ball bearings – this will reduce wear on the construction and improve smooth operation.
I am skeptical of simple "lubrication solutions" that do not address the main causes of stress and material fatigue.
lochen
12 Feb 2020 10:52
To summarize and practically add to the points made by taudi and plo60:
First, you should identify the exact cause of the problem: Does the drawer just start to stick, or is it misaligned? This can be due to faulty installation or warped side panels.
Check whether the drawer slides are mounted perfectly square to the chest of drawers. Even a slight misalignment when screwing them in can cause problems later on.
I also recommend loosening the screws slightly during maintenance, then carefully aligning the drawer before tightening the screws again. This method makes precise adjustment easier.
If you feel confident: some users add small felt pads or foam strips at contact points to reduce friction.
Finally: moderate loading and even distribution of weight are essential – a perfect sliding mechanism won’t help if the load is unevenly placed.
I hope this helps!
Repar
13 Feb 2020 07:28
Regarding your topic, I recommend:
- Check and tighten screws on the rails.
- Clean dust from the drawer slides.
- Apply a thin layer of silicone spray.
- Distribute drawer load evenly.
If the drawer sticks, inspect the guide and adjust if necessary.
