ᐅ How can I protect Billy shelves from high humidity?
Created on: 1 Feb 2021 08:34
NAU_EASON
NAU_EASON
1 Feb 2021 08:34
I am facing the issue of wanting to place Billy shelves from IKEA in a room with high humidity. Unfortunately, I have read that the particleboard used in these shelves can swell quickly when exposed to constant moisture. My question is: What specific measures can I take to effectively protect my Billy shelves from the effects of high humidity?
I have already considered applying varnish or special sealants, but I am not sure what works best and makes sense in the long term. Any tips on proper placement or indirect humidity control would also be very helpful. Thanks in advance for your experiences and advice!
Luciandi
1 Feb 2021 09:12
Hello NAU_EASON,
I completely understand why this topic is important to you, since a lot of effort goes into setting up furniture and moisture can cause such damage. I have Billy shelves in my basement apartment, where it gets quite damp in winter, and I’ve tried several things.
Firstly, regular ventilation has really proven effective for me – ideally airing out the room completely several times a day for 5-10 minutes to reduce moisture.
Secondly, I’ve treated the visible shelf surfaces with waterproof varnish. This provides some surface-level protection against moisture but needs to be reapplied periodically.
I also think it’s very important not to place the shelves directly on the floor, but to use small spacers or furniture feet to keep moisture away from the base.
Overall, a combination of these measures works pretty well, although of course, there’s no guarantee of complete protection. Maybe someone else will share more tips!
NIKA61
1 Feb 2021 10:03
Hi,
I recommend using acrylic-based paint or clear varnish. Important: make sure to thoroughly treat all edges and drill holes.
Do not place the shelf directly on the floor; it’s better to use small feet underneath.
Ventilation is essential in conditions of high humidity.
koneo
1 Feb 2021 12:47
Hello NAU_EASON,
With shelves like the Billy, which are made of lacquered or veneered particleboard, moisture can often be an issue because the boards may swell if water penetrates.
I would recommend the following:
1. Seal all shelf parts continuously with a waterproof varnish or a sealant suitable for furniture wood. Be sure to treat the back and all cut edges as well. These areas absorb moisture particularly easily.
2. Raise the shelves slightly off the floor using small plastic or rubber feet. This prevents direct contact with water and improves air circulation.
3. Place the shelves with some distance from walls, especially exterior walls, as these are often colder and more humid.
4. If possible, install a dehumidifier or regularly ventilate the room thoroughly to reduce indoor humidity.
5. If the room cannot be heated adequately, it can also help to replace the shelves’ back panel with a water-resistant panel made of sturdy plastic.
I know this may sound like a lot of work at first, but this is how you can make Billy shelves durable when moisture levels are high.
If you need accessories like furniture feet, IKEA offers some affordable options.
Hope this helps!
JAPLO
2 Feb 2021 07:22
I would like to add that wood-based materials can lose mechanical strength when exposed to high humidity. Applying a water-repellent sealant is therefore advisable, but simple painting may not always be sufficient if the relative humidity remains above 60%.
koneo schrieb:
install a dehumidifier or regularly ventilate the room with quick bursts of fresh air to reduce indoor humidity
These measures should definitely be prioritized. Alternative materials such as metal shelves or plywood shelves with higher resistance to moisture can sometimes be more suitable.
If it has to be Billy, I recommend additional monitoring of the indoor humidity—hygrometers are inexpensive. This way you can take timely action.
The idea of installing a water-repellent back panel is good, but only if it is sealed airtight, because trapped moisture between the back panel and the wall can also cause damage.
CORYGAU
2 Feb 2021 09:14
I find the assumption that you can reliably protect a Billy shelf from high humidity simply by painting it and raising it off the floor somewhat confusing.
Luciandi schrieb:
On the other hand, I treated the visible shelf surfaces with waterproof varnish
That might be okay for short-term protection, but these veneer panels especially absorb water through the edges. The paint often does not provide a lasting seal. The issue lies in the material properties, not just the lack of protection.
I also agree with the recommendation to use a dehumidifier, but the energy and cost involved should be considered in balance.
Alternatively, you might consider more durable shelving systems made of metal or coated MDF boards. The idea of optimizing the indoor climate is definitely essential, otherwise it’s like fighting a losing battle.
I would also suggest questioning the storage location of the shelves within the room—perhaps there are cooler or drier corners? In general, engineered wood is a suboptimal material for areas with permanently high humidity.
