I recently bought several MALM dressers from Ikea because they fit well in terms of price and design. However, I’ve noticed that especially when fully loaded and with more frequent drawer use, they don’t feel very stable – they wobble slightly and generally lack firmness.
I’m specifically interested in how to significantly improve the stability of MALM dressers without completely rebuilding them or using unusual materials. Are there any proven tips or tricks, such as adding reinforcements, support plates, screws, or similar, to make the furniture more secure and durable?
I look forward to your advice, especially on long-term solutions that are practical and do not compromise the appearance too much. Thank you!
Hello tuleo,
First of all, an important point: MALM dressers are, as you probably know, designed to IKEA standards, which is typical for lightweight furniture. This means the material is often thinner, and the connections rely on simple dowels and screws that are not always very strong.
To improve stability, I recommend the following steps:
1. Add extra reinforcement: For example, you can use metal angle brackets screwed inside the corners of the dresser (behind the back panel or on the sides). This provides significantly more resistance against lateral wobbling.
2. Strengthen or replace the back panel: The thin chipboard back panel can be replaced with a thicker OSB or plywood panel. This greatly increases lateral stiffness.
3. Improve floor grip: Small rubber pads or special furniture feet with non-slip properties prevent tipping or sliding.
4. Check screws and tighten or secure them with wood glue if necessary: Sometimes screws or dowels loosen after assembly. Using quality wood glue (such as polyvinyl acetate) and careful tightening can reliably improve this.
5. Inspect drawer slides: Cheap plastic slides can deflect under load. Upgrading to metal slides can enhance the drawer’s stability and thus the overall sturdiness.
One more question for clarification: How many dressers do you have exactly, and how are they loaded? Are they standing on a completely level floor? Are there specific load points, such as heavy items on top?
A clean assembly on a solid base with additional metal brackets has worked very well for me. Feel free to ask if you want more detailed tips on these points!
chentan schrieb:
1. Add additional reinforcements: For this, you can use metal angle brackets that are screwed inside the corners of the dresser (under the back panel or on the sides). This significantly increases resistance to sideways wobbling.Exactly, that’s a sensible starting point.
Looking at MALM dressers, the basic construction usually consists of 16 mm (about 5/8 inch) particleboard, which tends to flex easily, especially when connected only with dowels. The metal angle brackets, which you can find at hardware stores as "angle brackets" or "corner braces," should be at least 30x30 mm (about 1¼ x 1¼ inches) in size and fastened with at least 3 screws per side.
Here is a structured approach to make the result neat and stable:
- Completely empty the dresser and, if possible, carefully detach the back panel.
- Replace the back panel: instead of the thin back cover, cut a slightly sturdier 6 mm (about 1/4 inch) plywood sheet and attach it with small screws and wood glue. Additional edge strips can help fix the panel without tension.
- Install angle brackets inside all corners on the back and sides. Make sure the brackets do not interfere with the drawer slides.
- If needed, replace the lower legs with screw-in furniture feet made of wood or metal. These allow leveling, which improves stability significantly if the floor is not perfectly even.
A side tip: If you often load the drawers heavily, consider installing stronger, self-closing drawer slides (for example, full-extension metal slides).
Finally, check everything multiple times: tighten screws, including dowels, and recheck the dresser for unevenness after the modification.
This way, you can bring the MALM compromises to a very good level of stability.
tuleo schrieb:
I am specifically interested in how to significantly improve the stability of MALM dressers without completely rebuilding them or using unusual materials.To meet your requirement of not using unusual materials, I still recommend replacing thinner back panels with sturdy plywood boards made from commonly available wood materials.
A full rebuild can be avoided by using metal corner brackets, which can easily be fixed into the existing structure with short screws.
Additional strong attachment points can be created by adding durable wood screws at key joints (side panels, shelves).
It is also ideal to regularly check and tighten screws, as temperature changes and load usually cause some loosening over time.
I also suggest that dressers with heavier loads be secured not only to the wall but also supported at the base using furniture feet with rubber pads to better distribute the weight and prevent wobbling.
