ᐅ How can I make Malm dressers more stable?
Created on: 24 Feb 2017 08:37
silera
silera
24 Feb 2017 08:37
I have several IKEA Malm dressers in my bedroom, but I have noticed that they tend to feel somewhat unstable, especially at the back panel and at the feet when loaded. My question is: How can I make Malm dressers more stable, both to stand better and to prevent them from loosening or wobbling with daily use? Are there proven methods or practical tips to reinforce the structure permanently without affecting the appearance? I am particularly interested in whether adding extra bracing, special base pads, or wall anchors is useful, and how to install these in the best way without damaging the dresser or requiring complicated modifications.
reoWilhelm
24 Feb 2017 09:12
silera schrieb:
How can I make Malm dressers more stable or secure them so that they not only stand better but also don’t loosen or wobble with daily use?
Hey, I’m familiar with the issue with Malm dressers since they are built quite lightweight. A simple trick is not to place the dresser directly on the floor but to stick small self-adhesive felt pads or non-slip pads under the feet. This also prevents them from sliding on smooth flooring.
In addition, I would definitely recommend using wall anchors (which IKEA offers). This adds a lot of stability and is relatively easy to install. The dresser is basically secured against tipping over – practical and safe 🙂
For stability itself, it can also help to reinforce the back panel from the inside with small brackets. Not absolutely necessary, but if you’re handy, it strengthens the whole structure quite well. Good luck securing it!
JAMESON
24 Feb 2017 14:21
silera schrieb:
Are there proven methods or practical tips for permanently securing the structure without affecting its visual appearance?
Wall anchors are the best choice.
For stabilizing the supports, I recommend non-slip rubber pads.
Glue the back panel with small metal brackets.
silera
25 Feb 2017 07:59
That’s a good tip, thanks. I actually have it standing on a wooden floor and haven’t used any special underlays beneath it so far.
Could you please explain this in a bit more detail? Glue or screw in? I’m concerned that the back or side panels could be damaged by too much pressure if I attach metal brackets. Are Malm dressers generally stable enough with the back panel alone, or is it recommended to reinforce them by installing brackets?
Also, I’m curious whether the use of wall anchors must comply with certain standards when mounting to a wall—I have a drywall (plasterboard) which surely won’t hold as well as stone or concrete.
Thanks in advance for your advice. I want to secure this as durably as possible without damaging the dresser or having to do major modifications.
