ᐅ How can I modify Malm drawers to make them more child-friendly?
Created on: 1 Jan 2024 08:37
resulmin
resulmin
1 Jan 2024 08:37
I’m looking for ideas and practical tips on how to make my Ikea Malm dresser safer for children. It is especially important for me to implement measures that prevent fingers from getting pinched or caught, and to make the drawers more secure against accidental removal. Are there any proven mechanical modifications or accessories that fit well? Additionally, I’m curious whether the material of the Malm drawers is suitable for remodeling, or if you know of alternatives that are more child-friendly. Thanks in advance for your input!
BOMILAN
1 Jan 2024 09:02
Installing drawer locks prevents accidental pull-outs. There are also furniture stoppers that prevent pinching. Suitable retrofit kits are available for Malm.
kieran
1 Jan 2024 09:45
To prevent finger pinching, I recommend installing drawer dampers combined with soft-close mechanisms. The Malm series from IKEA usually has simple drawer slides that can be somewhat unsafe without these features.
Installing drawer locks made of plastic or metal provides additional protection against drawers being pulled out completely. It is also important to reduce the weight of the drawer contents to minimize any risk of the chest tipping over or rolling away.
The material of the Malm drawers is typically MDF or chipboard with a laminate coating, which is suitable for drilling or adhesive mounting. Alternatively, wooden strips are a good option for protecting edges.
nonpra
1 Jan 2024 10:17
You can prevent finger injuries by using dampers or stop strips. Simply attach edge strips to the inside edges of the drawers; this prevents pinching.
TRADI
1 Jan 2024 11:03
Hello resulmin,
I understand that safety is the top priority when it comes to children. In addition to the drawer locks you mentioned, you can also install so-called toy locks, which prevent small children from fully pulling out the drawers.
Sometimes adding extra handles or large, soft rubber profiles can help to avoid pinching at the edges. I also recommend securing the Malm dresser to the wall with a furniture anchor to prevent tipping – this is a very important safety aspect.
I have often used tension locks that simply fit into the rails to limit how far the drawers can be pulled out.
If you like, I can provide you with details on how to install them.
bapar
1 Jan 2024 11:56
To make the Malm drawers truly child-friendly, I would proceed as follows:
1. Safety latches or drawer locks: These prevent children from pulling the drawer all the way out. Some systems use small metal catches that engage if the drawer is opened too far.
2. Retrofit soft-close dampers: Ideally, hydraulic or rubber-sprung dampers that also prevent finger pinching by closing gently.
3. Line the inner edges of the drawers with foam profiles or rubber edge protectors to avoid injuries from sharp edges.
4. Furniture anchors for wall mounting: This is an absolute must, especially with children and higher dressers, as kids often like to climb on furniture.
5. Material handling: Since Malm drawers are made of MDF with lacquer or foil finishes, pre-drilling carefully is important to avoid damaging the surface.
6. Alternative: Replace the drawer fronts with versions featuring ergonomic handles or opening mechanisms that will not confuse or surprise children.
In general, I would recommend tailoring all solutions to the specific use and age of the children. If you can provide details about the dresser’s exact construction, I could also suggest devices I found, for example, in technical product databases.
