ᐅ How can I make IKEA Metod kitchen cabinets more stable?
Created on: 25 Aug 2020 19:11
Laalcibiad
Laalcibiad
25 Aug 2020 19:11
Hello everyone!
I recently planned an IKEA Metod kitchen and have some concerns about the stability of the individual kitchen units. Especially the tall cabinets and base cabinets feel relatively lightweight in construction, and I want to make sure they remain sturdy during long-term use and under load.
My specific question is: What options and methods are available to reinforce IKEA Metod kitchen furniture without compromising the appearance or functionality? Are there special reinforcements, assembly tips, or additional materials I could use? Perhaps you also have experience with securely fixing the cabinets to the wall and floor or stabilizing the entire carcass.
I look forward to your ideas and advice!
Mufato
25 Aug 2020 19:43
Laalcibiad schrieb:
What options and methods are available to make IKEA Metod kitchen cabinets more stable without compromising their appearance or functionality?
I would always make sure that the cabinets are properly leveled and plumb. Additional metal brackets at connection points can help a lot.
Fixing the cabinets to the wall and using screws in the back panel also reinforce the whole structure.
TYRELL
26 Aug 2020 08:55
There are several practical methods for reinforcing IKEA Metod kitchen cabinets, which I would like to explain in more detail:
- First, gluing the inside corners of the cabinet carcasses with wood glue is a simple way to increase the stability of the cabinet frames. This can help prevent joints from giving way under load.
- Additionally, using metal brackets or corner braces mounted on the inside of the cabinet sides is very effective. These should be high quality and precisely fitted, and secured with appropriate screws.
- For wall mounting, I strongly recommend using suitable screws and wall plugs that match the wall material. Screwing in at an angle increases tensile strength. The metal L-brackets must be sufficiently sized to support the weight.
- For base cabinets, which often stand on a plinth, attaching an additional reinforcement strip to the back can help prevent the cabinet from twisting.
- For maximum security, installing a thin plywood panel as an additional back panel from the inside provides significantly more stability than the thin IKEA backing.
Can you say whether you have identified any specific weak points in your cabinets, or are you looking for general improvements for all of your furniture?
dunitan
26 Aug 2020 11:09
TYRELL schrieb:
For those who want to be extra sure, you can also install a thin plywood panel from the inside as an additional back panel, which provides much more stability than the thin IKEA back panel.
This is an important tip! The original back panel in Metod is very thin and mainly supports the shape stability, but not the load-bearing capacity.
To improve this, you can also use extra edge strips or metal connector plates. This will prevent the cabinets from twisting over time.
Also, when assembling, make sure all screws are tight and the hinges are not overloaded. It can help to fix the cabinets again after assembly at the joints with some silicone or construction adhesive, without making disassembly difficult.
The suggestion to reinforce the base is also practical – cabinets often settle slightly over time, and this can help prevent that.
If you like, I can provide you with a list of the most durable mounting materials and tools – so you will be fully prepared.
