ᐅ How can I make Malm drawers close more softly?
Created on: 7 May 2020 08:14
keoju2
keoju2
7 May 2020 08:14
Good morning everyone, some time ago I bought a few IKEA Malm dressers, and I’ve noticed that the drawers close quite hard and loudly during use. I’m looking for ways to make the drawers close more softly without having to handle them very carefully. Are there any specific tips or adjustments that can be made to the drawer slides or dampers? My dressers have the standard metal slides without a soft-close feature. Replacing them with longer soft-close fittings is an option but rather complicated. So, are there any simple solutions or modifications to dampen the existing slides a bit? Thanks in advance for your advice!
lofar
7 May 2020 08:47
Try attaching felt pads or strips of foam rubber on the inside edges of the drawers. This noticeably cushions the impact when closing.
Palenar
7 May 2020 09:35
Your question about how to make Malm drawers close more softly is a common topic with several possible solutions. First, it is important to know the type of drawer slides, as Malm models without soft-close typically have simple metal runners with minimal damping.
1. Adding Soft-Close: There are universal soft-close adapters for metal drawer slides available at hardware stores or online. These clips simply snap into the track. It is important that the slide is straight and that the adapter is of good quality; otherwise, the closing action may become uneven again.
2. Cushioning: As mentioned, attaching felt or foam between the drawer and the cabinet frame can help. It is best to try several thin layers so the closing path is not obstructed.
3. Cleaning Rollers or Tracks: Sometimes, hard closing results from dirty or poorly running slides. Thorough cleaning and, if needed, lubrication with dry silicone spray to avoid residues can help.
I also wonder if your drawers have been worn in evenly or if they might be sliding crookedly. If the drawer runs straight and closes properly, damping solutions can work better; otherwise, the mechanism may need readjustment. Can you confirm this?
keoju2
7 May 2020 10:02
Palenar schrieb:
I’m still wondering whether your drawers are running perfectly smoothly or possibly running crooked.
Thank you for the detailed response. Yes, the drawers operate mostly straight, and I assembled the dresser just recently. The runners are clean and show no visible damage. Unfortunately, I don’t have a soft-close function, so I would like to try a more affordable option. Is there any feedback on the soft-close adapter clips and how well they actually engage? I have read mixed reviews about them.
Ryker66
7 May 2020 10:15
Soft-close adapters generally work well if installed properly. They need to fit correctly, though, as the quality of cheaper versions can vary. Felt or foam rubber is the simplest alternative.
Ernesto
7 May 2020 14:28
Regarding the topic of soft-closing for Malm drawers, I would like to add that retrofitting soft-close adapter clips may seem simple but involves certain technical requirements. First, the rails must be mounted exactly at the same height so that the adapter engages correctly. Additionally, these clips use a spring mechanism that slows down the last centimeter of the drawer.
Some models use oil-filled dampers, which are more expensive, while others rely on delicate springs. Therefore, if you want to retrofit cost-effectively, I strongly recommend choosing quality products, as cheaper adapters can sometimes stick and block the drawer.
Alternatively, there are so-called "soft-close mechanisms to stick onto" the cabinet, where a small damper flap prevents slamming. These are well suited for simple drawers and are easy to install yourself.
I would also like to ask how much load your drawers need to support and whether you frequently store heavy items. Retrofitting can change the running behavior if it is not perfectly matched.
