ᐅ How can BILLY shelves be protected against moisture?
Created on: 12 May 2019 09:07
BAUPLO
BAUPLO
12 May 2019 09:07
I am planning to use some Billy shelves from IKEA in my rather damp basement to store books and various items. However, I am concerned that the material of the shelves—mainly the wood-based panels—might swell or get damaged due to the moisture.
My question is: How can Billy shelves be protected against moisture so that they last as long as possible in such a damp environment? Are there any specific treatments, coatings, or construction measures I can take?
I am thinking about making the wood somewhat water-repellent, but I am worried that some products might discolor the surface or leave an undesirable shine. Does anyone have experience with this?
Thanks in advance for your tips and advice!
FAZAR
12 May 2019 10:36
Hello BAUPLO,
First, it would be helpful to know the approximate humidity level in the basement (relative humidity in %), and whether there are any direct wet spots or just elevated humidity.
BILLY shelves are made of particleboard with a melamine coating. These are generally not waterproof and will swell when exposed to moisture, especially at cut edges and the back panel.
To minimize the risk, I recommend a multi-step protection approach:
1. Seal edges: The often unprotected edges can be well treated with waterproof clear varnish (e.g., multiple layers of polyurethane or acrylic varnish). This significantly reduces moisture penetration.
2. Seal the back panel: Additionally, you can apply clear, waterproof sealants or sealing tapes, as the back panel of BILLY shelves is usually thinner and can swell quickly.
3. Under-shelf insulation: The shelves should never stand directly on the damp floor. A suitable base (e.g., waterproof plastic sheets or special shelf feet) provides clearance and prevents capillary moisture transfer.
4. It would also be useful to ensure good ventilation in the room and, if necessary, use a dehumidifier to address high humidity levels.
If you want to paint the shelves, I recommend a waterproof wood protection varnish that is transparent and suitable for particleboard. It is best to test a small area first to rule out any discoloration.
A quick question: What exactly does your basement look like? Are there areas that regularly get wet or remain damp and humid?
Mariah
12 May 2019 12:17
FAZAR schrieb:
BILLY shelves are made of particleboard with a melamine coating. They are basically not waterproof and will swell when exposed to moisture, especially at cut edges and the back panel.
That sums it up perfectly!
I once had my BILLY shelves in a guest bathroom that could get quite humid at times. What really helped was treating the edges with clear furniture wax. It doesn’t make the surface too shiny and protects against moisture. Plus, it gives the wood a nice, slightly warm tone.
I also placed the shelves on small plastic feet to keep them off the floor — this really helps to prevent moisture from coming up from underneath.
Small extras like silica gel packets can be placed inside to absorb any excess moisture.
All in all: with a few simple tricks, you can protect your BILLY shelves quite well, even though they aren’t meant for very damp rooms. And don’t worry about a bit of wax on the wood — it’s more of a benefit than a drawback 🙂
FAZAR
12 May 2019 14:25
Mariah schrieb:
I once placed my BILLY shelves in a guest bathroom that was occasionally quite humid. What really helped was treating the edges with clear furniture wax.
Interesting tip! Furniture wax actually provides a breathable protective layer that repels moisture without fully sealing the surface. However, you should definitely check that it is suitable for particleboard and not too greasy, to avoid a sticky finish.
BAUPLO schrieb:
Are there specific treatments, coatings, or construction measures I can take?
As a construction measure, I would like to emphasize elevating the furniture, for example by using spacers. Alternatively, a simple wooden batten that has been pre-treated with wood preservative can be placed underneath.
For more demanding situations, it would be advisable to choose furniture made from solid wood or MDF with a water-resistant coating instead of BILLY.
In general, no panel material should be exposed to high moisture levels over a long period, since even good protective measures only delay but do not prevent damage to the material.
JAPLO
13 May 2019 08:52
As an additional practical tip:
If you want to make the BILLY shelves truly resistant to moisture, you can apply a water-repellent wood preservative as an extra protective treatment. The product should be suitable for coated wood-based materials, preferably acrylic-based, to avoid damaging the surface.
Be sure to apply several coats on all cut edges and rebate areas to prevent moisture from penetrating the material. This significantly increases the lifespan.
It is also important to allow the shelves to dry completely before installation and to avoid placing them close to water sources.
And as FAZAR already mentioned: keeping the shelves off the floor is essential. It is best to use adjustable feet or pads made of plastic or rubber to prevent moisture from being absorbed through capillary action.
Teonon
14 May 2019 19:33
JAPLO schrieb:
If you really want to make the BILLY shelves highly resistant to moisture, you can also apply a water-repellent wood preservative as an additional treatment.
Wow, great information so far! It really encourages me to make my shelves more secure.
I also appreciate that you mention the small details like edge sealing and the distance from the floor – these things are often underestimated.
I once applied a sealing paint on MDF boards in my apartment, and it worked really well: the boards felt quite durable afterwards, and the paint remained matte without any shine – maybe that could be an option for BILLY as well?
Question for all the experts: How does sealing paint compare to traditional clear lacquer or furniture wax? Are there any disadvantages?
Thanks in advance for all the great tips up to this point! 🙂
