I am looking for the best ways to protect my BILLY shelves from scratches. Since the shelves are made of wood fiberboard with a melamine coating, I am unsure which protective measures are truly effective. I especially want to avoid unattractive scratches caused by placing or moving items, as these not only look bad but also damage the surface.
Does anyone have experience with special protective films, surface sealants, or padding? I am asking in detail because I have read that some substances can damage the melamine coating. Additionally, I am interested in practical tips on how to prevent everyday scratches, such as what to place on the shelves or how to care for the shelf properly.
Thank you for your help!
Hello ILKER,
I can definitely help you with this – I have several BILLY shelves myself and have protected them from scratches.
Basically, the melamine coating is quite durable but not invincible. My recommendation is the following approach:
1. Protective film: There are special transparent protective films for furniture surfaces that you can easily cut to size. Make sure they are suitable for melamine, as some plastic films can react chemically and damage the surface.
2. Felt or foam pads: I stick these under items that I place on the shelves. This prevents direct friction and thus scratches.
3. Surface sealing: I advise against using varnishes or sealants because they can alter the melamine surface and often leave visible edges. If you still want to try a sealant, test it first on an inconspicuous spot.
4. Regular cleaning: Dust can also cause scratches when objects are moved. Use a damp microfiber cloth and avoid harsh cleaners.
In summary: use an appropriate protective film for large areas and stick felt pads under items you frequently move. That way, you’ll stay on the safe side.
Hope this helps!
Hope this helps!
LOGEMIN schrieb:
Use a suitable protective film for large surfaces and stick felt pads under items that you move regularly.That’s a good approach. Additionally, I would like to point out that many protective films in cheaper offers have low adhesion and tend to peel off over time. Therefore, I recommend using films from reputable suppliers explicitly marketed for wood and melamine surfaces.
In my experience, it’s also best not to place heavy or sharp-edged objects directly on BILLY shelves without a protective layer underneath. Combined with regular cleaning, this significantly reduces mechanical wear.
One last tip: if the shelf is located in high-traffic areas, such as near entrances or frequently used pathways, it’s worth protecting the shelves with decorative table runners or thin fabric mats. Practical and visually appealing.
ILKER schrieb:
I especially want to avoid unsightly scratches caused by placing or moving objects,At this point, it is important to consider the physical aspect: scratches usually occur due to localized pressure points on the surface.
Therefore, I recommend using items with a larger contact area or made of softer materials as buffers. Rubber feet or silicone pads distribute pressure better than hard plastic or metal feet.
Regarding the protective measures you already mentioned in your post: of course, you should avoid using oil- or solvent-based products, as these can damage the melamine coating.
Additionally, regular inspection and careful placement can help. Sensitive areas, such as edges, are particularly prone to damage.
anken schrieb:
practical and looks good Thanks for the tip about table runners and fabric mats; I hadn’t considered that before.LOGEMIN schrieb:
test them first in an inconspicuous spot That’s a good suggestion, as I have actually been considering a sealant, but now I see it might be better to approach that carefully.
Does anyone have experience with removable protective films? I’m concerned about residue or damage when removing the films later.
Also, I have an additional question: How do you handle the back panels of shelves? Are there any protective measures you use to prevent scratches when loading them?
